A good way to remove pinion bearings!
Discussion in 'The Garage' started by diesel4me, Aug 10, 2003.
  1. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    I saw this trick at a local big rig shop--if you are changing the pinion bearing behind the driveshaft yoke,and the outer race(cup)wont come out--the guy fired up his arc welder and ran 3 small beads on the race in 3 equally spaced spots,being careful not to weld on the case itself--then a dentist pick kind of tool was able to wiggle it right out! /forums/images/graemlins/shocked.gifI guess welding on the hardened steel shrank it enough when it cooled to fall right out--slick trick!Saved him lots of time and labor.This would work on other bearings as well like wheel bearings too!. /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yep been there done that /forums/images/graemlins/thumb.gif works good. I used to just runa small bead all the way around the race. then just let it cool and it pops right out /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    cool trick, never seen that one.
  4. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    I always had problems removing U-joints, didn't have a press, and I ruined two vices. A cutting torch removes the cross pieces in short order and the bearing cups tap right out with the right size socket. Heat is a good thing. Nike
