A gremlin jumped into my carb today........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Apr 10, 2001.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    VERY WIERD!!!!!!!!!!!! Today I fired the K5 up. It jumped to high idle right away. After about 2 minutes I went out and kicked her down to mid-idle(around 1000RPMS), and that's when the FUN started......
    The engine would start to choke itself out, and after about 20 seconds of slowly losing RPMs(down to about 350-400), it suddenly jumped back up to mid-idle. This happened THREE times in about 5 minutes, and then ran fine.
    <font color=red>WTF?????!!!!!!!</font color=red> <font color=blue>WTF??????!!!!!!</font color=blue>
    Can somebody please explain what's happening????? It's a 4bbl electric choke Quadrajet...........
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Sounds like the gremlin is messing with the idle control solinoid or the sensor it reads from (if there is one).
    That is a weird one! A beebee gun should take him out though! LOL
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. Can Can
    15,552
    136
    I just flipped through my Haynes manual and couldn't find any mention of an "idle control solenoid". Is my 84 equipped with one?
  4. Can Can
    15,552
    136
    Any more ideas, guys?? Hmmmmmmmmm- Where's Grim when you need him? Probably changing a diaper!!!!!!LOL
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I think that's what it's called. I'm prolly wrong then. *calling* Grim! Oh Grrriiimmmm!!!
  6. Grim-Reaper
    7,385
    Atlanta
    Been here done this..the electric choke element sounds like it fried and the choke is stuck on and flooding out the engine. First check that your getting 12 v on the wire to the choke if you are then the heater in it has probably failed. I forgot what the ohm rating is when it's good. Maybe somebody else will know and you can meter it before spend the $35 for a new one. Also a bad electric mix solonoid could ase this issue but not sure if that was on your truck or not. If it is even if one wire is getting 12v the other wire on the mix control runs to a thermostatic switch on the water neck and you need to meter that to see if it is activating the mix solonoid.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  7. dyeager535
    26,980
    Your '84 should definitely NOT have an MC (mix control) solenoid, unless maybe it was originally a CA truck.
    Dorian
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I think I'm in the midst of the same prob with my '82s electric choke. 90% runs great but every now and then the exhaust is darker and it runs rough. Get the truck warmed up all the way and its fine. Or just sometimes turning it off and starting it again. It was doing something similar to what the original mentioned, I pulled off the air cleaner and somebody removed the hose going to the manifold for my thermal vacuum, no heated air for the intake. I've got the carb rebuilt, new distributor, MSD wires, AC plugs, so its gotta be the choke.
