A Guide to SEARCHING ColoradoK5.com Forums
Discussion in 'The Garage' started by scrappy88, Aug 30, 2005.
  1. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    A guide to searching ColoradoK5.com Forums:
    I see a lot of new threads started here that have been answered a million times over the years. Questions like "how strong is my 10 bolt" or "what lift do I need to clear 35's" etc. Many of these say they have searched the forums but didn't find what they are looking for.
    There is a HUGE amount of information in these forums, going back to 2000. The key to finding what you're looking for (and it is more than likely in here somewhere) is the search and understanding how it works. It is a bit tricky and often doesn't bring up what you are looking for right away. So here are a couple tips on how to outsmart the search feature:
    1) Common search words and exact phrases. There are a number of words that will be omitted from a search phrase simply because they are considered too common.
    Take for example a search for center pin. After doing that search the forum will display up in the header "The following words are either very common, too long, or too short and were not included in your search: pin". So what you get is just a search for the word center and that probably won't get you anywhere. If you aren't finding what you're looking for, be sure to check if the search is omitting some of your search terms. If it is, try and search for the exact phrase by enclosing it in quotes: "center pin". This will turn up threads that contain the exact phrase center pin even though the forum would normally omit the term pin.
    You can combine exact phrase searches with regular searches to further narrow the results down. For example, if you want to search for the phrase "center pin" and the words spring and bolt you would simply type "center pin" spring bolt into the search field. One note about doing this: When doing a search like this, the forum will only highlight the terms that aren't in quotes. I'm not sure why.
    2) Wildcard searches. Another thing about the forums here is the fact that the search feature will not find words within words. For example, let's say you wanted to search for the word shock or tire. Searching for terms like that will turn up shock and tire but not shocks or tires. Get around this using wildcards: Search for shock* and it'll come up with shock, shocks, shocked, shocking, etc.
    You can combine wildcard searches with exact phrase searches ONLY if the wildcard is NOT part of the exact phrase in quotes. For example: searching for "shock mount*" will not work. Searching for "shock mount" spring* will work fine, returning results that contain the exact phrase shock mount AND any word starting with spring (springs, springy, springer etc.) Wildcards can be used before, after, or in the middle of a word.
    Learn these and you'll have much better results, and will probably never have to ask "can I fit 35s on a 2 inch lift" again.
    If anyone has more tips on searching please post them up here. :thumb:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Sticky this :thumb:
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Dito that.
    Good job
    :waytogo::waytogo::waytogo:
  4. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    I Agree Please Use The Search And We Will Help If Needed After That. Thanks Have A Great Day All.:d
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    If you want to find a 3 letter word or acronym like TBI, use TBI* ;)
  6. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Definately! :waytogo:
  7. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    so....how much lift will clear 35's????? :haha: :haha: :haha:
  8. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Great tip...:waytogo:
  9. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Wow, I didn't know the second tip. Def. sticky this.
  10. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Sticky!!!
  11. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I also didnt know that second tip. This post should be a sticky.
  12. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    ttt. Thanks Scrappy88. :D
  13. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Isn't it also correct say that if you search for say shock tower that you will get results for posts with either shock or tab or both shock and tab but if you search for shock +tab you only get posts with both terms in them.
  14. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    Hmm :thinking: I come up with the same results searching for shock tower and shock +tower. I think it automatically searches for shock and tower rather than shock or tower.
    Also as FWP pointed out, any 1 to 3 letter word or acronym you should follow up with a * because it looks like the search ignores all words less than 4 letters.
  15. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    I guess it is just habit. Some search engines auto include the "+" or "and" I guess this is one of them.
  16. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    back up top
  17. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    this needs to stay on page 1
    yep yep uh huh! newbies take heed i know i'm a newb myself but most just go to posting without ever searching it seem..thats why this was on page 7 and 1-6 had at least2-3 questions basically the same on each page
  18. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  19. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    You guys might want to consider making somekind of thread guide for the best threads or the most commonly asked questions because sometimes it is difficult to find somehting in a search. For example, I was trying to find a thread about oil for Diesels but doing a search for either of those key words would get you nowhere. I am sure there are a lot of other topics like this too.
