A.I.R. Pump and headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Shazam456, Mar 13, 2006.
  1. Shazam456
    Shazam456 Registered Member
    Oct 8, 2005
    15
    ontario
    Has anyone installed the air injection system for emissions into header pipes.
    I'm having trouble passing the e test in Ontario and the air pump is missing.
  2. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    I planned on going with a replacement cat that had the air tube built into it. Than I got lucky and picked up a set of headers that had the injection tubes in the same location as stock manifolds. I've had no problems passing emissions with it set up like that. :D
    Z
  3. dyeager535
    26,978
    Are you failing a visual or just a sniffer?
    An alternative would be to plumb an AIR tube into just one header pipe ala some of the early TBI trucks. They didn't use the AIR manifold with four ports, just one big tube dumping it into the manifold.
    Just an idea.
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    If youre interested I just took the dual air pumps off my '85 K30. I have the brackets and pumps, but not the rest of the system.
  5. Shazam456
    Oct 8, 2005
    15
    ontario
    Thanks Goose Man. How much for what you got and where are you?
  6. 86jimbo
    86jimbo Registered Member
    Sep 8, 2005
    59
    Arkansas
    i have a pump off of a 86 that works great ill sell ya.
  7. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    when i put headers on mime , i just drilled the proper size hole in the header
    and welded the piece in place then hooked the hose up . :waytogo:
  8. Goose
    1,127
    PM sent to shazam 40 plus the ride
