A.I.R pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Jul 21, 2002.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    So I am putting in my new engine and leaving out the A.I.R system. Aside from the check engine light is there any real problem I am going to have?
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I thought only the staight 6 motors had an AIR system?
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Maybe I am the crack smokers dialog tonite. ....its the smog system that injects/recirculates air into the system. Thought that was what the A.I.R. sytem was. Its on the 88K5 and its just taking up space. I am in the process of moving the old brackets over and dont want to deal with it. Unfortunately it has a sensor hooked to it.
  4. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    The only purpose my AIR pump is serving right now is for being a belt tensioner on my york. No sensor is hooked up to it and i haven't gotten a check engine light yet and it has been a year /forums/images/icons/laugh.gif
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You are correct, that is your AIR system. If you fully disconnect it, you could have problems passing visual inspection, depending on if they do that where you are. I originally disconnected mine on my original 305 by removing the belt 9obvious it wasn't working). The guy went through my rig with a fine-toothed comb at inspection and never seemed to pick upi on that. Since, I have completely removed mine. I pulled all the connections for it and installed non-AIR headers as well as removed the pump. I also have new pulleys that don't even have the extra groove. So, looking at my engine, there is no way to tell from observation that my rig ever had it. Haven't had to go back through inspection yet, so I don't know if it will pass.
  6. K5Crazy
    K5Crazy Registered Member
    Jun 28, 2002
    11
    Waterville, ME
    My 90' 350 doesn't have A.I.R. on it. And as far as we can tell it was never there. It's not on the emissions sticker ether, so I guess my Blazer didn't come with it? It says federal emissions on the sticker. Maybe the California and federal stickers are different?
    To bad federal still uses a cat.
    This Blazer was sold in the north east if it helps.
    Ken
  7. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks guys. I dont have the visual inspection here so I and teh only emissions testing I have....its done forever now. The air manifolds that I have are plumbed to eachother then have some sort of plug on the drivers side. Wonder what that is.
