A.i.r.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wishbone, Mar 20, 2006.
  1. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    I'm thinking about ditching all the smog control stuff since I don't need it. The belt to the smog pump is already off. The thing I'm not sure about is the purpose of the a.i.r. sytem. Is it tied into the smog stuff? I would like to put some headers on but would need to get rid of those extra valves coming into the manifold right?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The AIR system consist of the pump, AIR tubes and valves. If you don't need the emissions stuff then you can pull it all off.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I was going to ask this same question the other day, but I'll jump in here too. So i can just unhook the pump/belt, and all the associated tubes and hoses? Do you just plug the holes in the manifolds with something? I have a tube running from the drivers ide valve cover into the bottom of the air cleaner. Kinda like a PCV, but with no valve. Can i just replace that with a PCV because I would like to switch to an open element. This is on a 454 btw if it makes any difference. My K5 has non of this stuff on it so i have never delt with any of the air stuff.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes, you can install plugs into the exhaust manifolds to get rid of the AIR tubes.
    To answer your question, No. You need to retain the breather tube from the valve cover to the air cleaner and also the PCV valve to the carb/TBI. If you disconnect the breather tube then you are disturbing the PCV system and you are sure to start developing oil leaks because of too much crankcase pressure building up.
  5. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    What is good to use to plug the holes left in the exhaust manifold?
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Fairly sure they are 5/16" inverted flare fitting plugs.
  7. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Take the EGR valve off while your at it too. You will either have to make or purchase a block of kit for it. I made my own out of a chunk of aluminum.
  8. kore0015
    kore0015 Registered Member
    Mar 1, 2006
    9
    Ft Lewis, WA
    I plugged the holes in my manifolds with plain old bolts from Home Depot. I just got a close thread match off of one of the fittings. Nothing fancy, but it works. If you're really feeling lazy I went a few years with a just pair of lug nuts shoved into the rubber hoses.
    If you still wanted to know, all the a.i.r. pump does is force fresh air into the exhaust as a way of basically cheating emissions. It was also designed to reduce backfiring, but who want to do that?
    I don't know about pulling the egr. I want to get rid of it too. Never done it, but it supposedly lowers combustion temp and reduces knocking in addition to all the emissions bull.
  9. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Yeah my egr valve has been long gone. Think I might attempt to take all the air crap off this weekend. Looks pretty straight forward. Don't know if I can actually take the smog pump off because of it's location. There is no belt running it but will it need to be capped off when I pull the hose off it?
  10. K5Kell
    K5Kell Guest
    What all is involved with pulling the EGR valve?
    -Kell-
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Unbolt the EGR valve from the intake, plug the port on the other end of the vacuum hose and make or buy an EGR block off plate.
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Does this have any ill effects on the computer like throwing codes and such?
  13. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Yeah it might dunno for sure. Mines an '84 so I have no computer. Be sure to put a gasket under the block it you do cap it off.
  14. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    What did yall do about the vapor canister when u pulled the EGR valve?
  15. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    Can I just remove the belt from the pump and leave the pump on there? That would be nice when emmissions testing time comes up.
  16. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Yes, that's the way mine is right now.
  17. dyeager535
    26,980
    Be careful doing this, inactivity seems to lead to bad pumps later. :(
