A.I.R.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Feb 9, 2004.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    is there a negative impact (other than emissions testing) to removing my smog pump and the A. I. R. manifolds from my exhaust. are there any sensors that rely on this stuff?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    No, Ive done it many times, it cleans up your engine bay.....but its illegal and wont pass the visual part of an emissions test.
  3. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    i posted the question as i search for a set of headers. i have read every header question that has been posted here for the last 2 years. it looks like the two best choices for keeping A.I.R. are the edelbrock TES and the doug thorleys. i have read that the thorley Tri-Ys seem to sacrifice too much low end torque. the edelbrock TES appears to be closer to a shortly (more low end sacrifice) than a long tube. i called edelbrock and they stated that the TES is not classified as a long tube header. if i lost the A.I.R, i could go with a hooker competition but i screw emissions testing... i think the next step is to go back and try to determine which of the two (edelbrock TES and D thorley) provide the best low end... i have read so much on this subject that my head aches...
  4. dyeager535
    26,979
    So whats wrong with Hedman part #'s 69488 or 61498?
    Both of those list "T.E.M.S. (Tubular Exhaust Manifold Systems) are 50 state legal for years listed in catalog only." for 1982-1987 1/2 and 3/4 ton trucks. Looks like only 61498 comes with the EFE valve, or a way to keep the original though.
    If I didn't have to go through vsual emissions I don't think I'd worry about AIR, but if there is any possiblity you might need to worry about it later, keep it.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah if you remove it then dont go bragging about it to the wrong ppl or you can get fined for it, that goes for any pollution controls equipment factory installed, the codes for each are lsited on emissions label underhood so that facilities know what is supposed to be intact
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I removed my stock manifolds for a set of competition hooker headers. I just removed the air lines that run in front of the intake.
