A link to good relay/elec fan info
Discussion in 'The Garage' started by supersize75k5, Jan 2, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I was looking into how to properly wire up my points to hei wiring and came across this info,
    the electric fan discussion is great information, I have been killing relays with my ford electric fan, this details the what, how and why of relays!
    awsome read,;)
    http://www.madelectrical.com/catalog/rly-1.shtml
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    How many relay's are you using with your fans?? Are you olny using the high setting? Since that fan draws so much at startup you need atleast 2 30 amp relays wired together for just high speed.
  3. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I did have it wired up with a single relay for high speed only,
    Now I plan to run a aluminum radiator and run the lowspeed fan with my temp switch and have the high on a manual switch with a really high setting on a adjustable switch 230 degrees as a back up for my bac up lol
    im just trying to un-getto my rig :)
