A little bit shaky first run....
Discussion in 'The Garage' started by RustBuket, Jun 28, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well I got my 33's on and I got the head gasket fixed and the engine all together. So, I go for my first run with big(to me) tires and its pretty cool but I am wondering why my truck shakes so bad when I accelerate. It did it mildly before but the tires have seemed to make the problem worse. This doesn't happen at high speeds or when I am coasting. What could it be? /forums/images/graemlins/confused.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Is your steering sloppy? Are the tires balanced?
  3. RustBuket
    Feb 21, 2003
    1,618
    I don't think its the tires or the steering box because the shakes are the worst when first getting going. Any other ideas?
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    can U say balance and align? + fix all the stuff you find loose/worn before the alignment. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Sounds like they need to be balanced and alligned or replace worn out parts like matty said /forums/images/graemlins/waytogo.gif
  6. RustBuket
    Feb 21, 2003
    1,618
    sounds like a whole pile more money...... /forums/images/graemlins/doah.gif O well....
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    joints? /forums/images/graemlins/dunno.gif
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Are you talking about wheel hop? Common when accelerating and the larger tires would make the problem worse. /forums/images/graemlins/dunno.gif
  9. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    my moneys on them old u-joints /forums/images/graemlins/thinking.gif
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    definetally sounds nothing like balance and alignment but everything like bad u joints. What are you running as far as lift? Anything? When you accelerate the pinion tries to move on the truck which with some bad u joints could be causing the vibration.
  11. RustBuket
    Feb 21, 2003
    1,618
    I have no lift. Just 33's with stock everything. I know its not wheelhop cause the 305 doesn't have the power to spin em. /forums/images/graemlins/rotfl.gif I'm thinking the U joints sound about right.
  12. RustBuket
    Feb 21, 2003
    1,618
    Ok well I solved the mystery! Apparently I was only running on 6 out of 8 cylinders.... I knew I couldn't of lost *that* much power to 33's... /forums/images/graemlins/rotfl.gif So I replaced a plug with a cracked insulator and taped up a wire and now she hits on all eight and feels MUCH better.
  13. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Better replace the wire as tape wont hold up very long and then you'll foul the plug and be right back where you started /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/usaflag.gif
