A little driveline tech-
Discussion in 'The Garage' started by drivelineman, Sep 18, 2006.
  1. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    Here's a new product were playing with -its a torque limiter - We are using these on a sand car application -we trying to save a 14 k trans from distruction- Jess:D
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I'll bite...how does it work?
    Rene
  3. drivelineman
    Aug 23, 2000
    707
    And one installed on a 1480 1/2 shaft -should hold up to 8000 ft-lbs-were starting at 5000 and working ur way up if it limits too soon- Jess
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Synopsis: When you exceed the rated torque of the limiting bolts, they break. The bolts cost $100 for three of them and the shaft is retained even when the bolts break. Yes, I read the pirate thread.
  5. drivelineman
    Aug 23, 2000
    707
    its a accurate device that will limit torque by the sheer in the special bolts they supply-it does hold the shaft together after it sheers-it will not flop around- available from 2000 ft-lbs to allot like 25000 hehe - Jess
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sweet mother of GOD!!! :)
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Nice...
  8. drivelineman
    Aug 23, 2000
    707
    these are all custom made at this point the flanges were made in house -the weight on these was 50 lbs- they have a beafy feel when you pick them up- Jess
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So its kinds like the rear brake rotors on freestyle bikes ? The unit is made like a unit bearing kinda , top and bottom rotate independently of each other until bolted together ?
  10. drivelineman
    Aug 23, 2000
    707
    here's the fancy little bolt there are three- Jess
  11. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Pretty good idea. I've seen these used for years on PTO driven shredders and other types of farm/ranch equip. We used a PTO driven drag behind shredder all the time on the ranch. Always had to replace those "torque fuses" when the blade of the shredder would catch a log or somethign else hidding in the tall grass. Finally about time they start using em in the auto world.
  12. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Those are the same style limiters as used on Frac pumpers on the driveline between the transmission and the pump all behind the 2250hp diesel V12 you bet they work.
  13. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I was reading an article on Suicide Sally while waiting to get my hair cut a couple months back and they were talking about this then.
    Jess have you checked out the rear drive shaft on her?
    -Avery
  14. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Hhmmm used to have to crawl underneath a 10 wheeler at spud harvest about twice a week to replace those things. They look a little different but same idea
  15. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    I've seen those for semi trucks
    awsome idea
  16. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    they had these in one of the 4x4 rags in the last few months. they called them torque fuses in there as well.
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    whats the starting price for one of those driveshafts? looks like beef
  18. drivelineman
    Aug 23, 2000
    707
    These driveline's are for sand cars- there 1200 per side- Thanks for the input - They are used allot on semi truck and ag stuff- Jess
  19. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Same idea as the Warn hub fuses then.
  20. drivelineman
    Aug 23, 2000
    707
    sort of but i think more workable-and accurate- Jess
