A little guidance needed
Discussion in 'The Garage' started by cojnit, Jul 16, 2003.
  1. cojnit
    cojnit 1/2 ton status
    Jul 23, 2002
    178
    Hawthone, CA
    I am not the mechanical guru but here goes:
    Apparently I blew up the rear end on my 95 2 door tahoe (Closest thing to a K5 I could get with a warranty at the time), along with destryoing the transmission (second one in a year). The dealer fixed the trans under warranty, and now tells me that they need $2200 to fix the rear axle and limited slip. the parts are being listed @ $1600. /forums/images/graemlins/deal.gif
    I think that this seems extremly expensive, and am lookin for alternatives. the questions I have are as follows:
    1. Is there something that can be easily swapped in that would give me more beef and rigidity? Also would not mess with ABS and would need minor/no fabrication?
    2. what would be the best way to replace the stock axle that would make it more trail worthy (for occational trail going, not hardcore rockcrawling).
    3. any thoughts where I could take it in the Los angeles or south bay area?
    Help is needed badly as this is my daily driver. /forums/images/graemlins/1zhelp.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    try and find yourself a 10 bolt from a truck with the same rear gears and put all your rear brakes onto it,keep any good spare parts that are left from your old one, and for 3-400 bucks you have a good rear end...
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    for $2200 your half way to a rear Camo 60.
    get one from a junk yard, buy it yourself and instal it.
  4. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    I agree with Zakk get out your yellow pages and start calling around and if ya need a hand putting it in send me a pm
    good luck in your hunt
    Randyu
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hell for that kind of cabbage you could get a semi floater D60 rear from a place liek Dynatrac or similar....
    I would find a rear axle from a junkyard or go the Dynatrac route. Another option would be to find a 14SF with the same ratio and swap it in with minor fabbing.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    What you want to find is a 9 1/2" semi-floating 14 bolt out of an '88 - '98 light 3/4 ton GM truck. This axle will have the 6 bolt lug pattern that matches your truck, and will be a bolt-in replacement for your 10 bolt. You should be able to find one through a local dismantler (with the gear ratio you need) considerably cheaper than having your 10 bolt fixed.
  7. cojnit
    Jul 23, 2002
    178
    Hawthone, CA
    have an offer for a 2002 stock 10 bolt with factory rear disk brakes ( mine had drums) I am not sure if this would work with the ABS and the spring perches (plus whatever other stuff I have no clue about) I will probably end up doing the work myself (with help from a fellow Big Dawg) and I am terribly afraid (yeah I am man enought to admit it) of getting in over my head with a swap that is way to complicated.
    Any further direction, or should I just abandon this fellow board members offer and find the 14 bolt SF?
  8. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    depends on the price! that shouldn't be a difficult swap for you. The 2002 should have ABS setup already on the axle so you may get very lucky in that regard. The 14SF is not only hard to find, but once you do, you'll end up paying a lot for it.
    Seems like your best bet is to find someone that just upgraded the rear axle under his/her K5 and get em to sell you the 10 bolt. Hopefully the gears match your front (3.73's?... shouldn't be too hard to find). Then just strip down the ends and replace with all your brake components. Move spring perches is time consuming (cutting off the hold, cleaning up the tube, being careful not to go through) but it is not "difficult."
    Don't sell youself short by spending more than you have to just so you don't have to face the unknown.
  9. LUBA
    LUBA 1/2 ton status
    Jan 16, 2002
    127
    Bay City, Michigan 48708
    I have the axle your looking for. 1997 Yukon 10 bolt rear 3.73 gears, Auburn, Moser shafts complete drum to drum- $350
    I also have the stock shafts one needs 4 studs-$50
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Best sense I've neard all day /forums/images/graemlins/thumb.gif
    Dealers around here qoute two prices on most big jobs - either all new GM parts, or recycled (used parts). Even had one dealer order up a 14SF for an 92-98 K1500 Burb at the customer's request. /forums/images/graemlins/grin.gif
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I think the whole pronlem is thet you want the dealer to do it.
