A Little Help
Discussion in 'Audio' started by ChrisM72beast, Dec 28, 2001.
  1. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    I need to know where I can put two amps and my cd changer in a stealth type of installation. Right now I have an amp under the drivers seat and the changer under the passenger seat. Now I'm adding a subwoofer only amp and I'm not sure where to put it. Keep in mind I don't have a rear seat. I'm thinking maybe the rear side panels but how do I get air to cool it off and yet keep it stealth? Any help would be greatly appreciated.
    Chris M
    <a target="_blank" href=http://www.geocities.com/chrism72beast/beastpage.html>http://www.geocities.com/chrism72beast/beastpage.html</a>
  2. big79209
    big79209 Registered Member
    Jun 15, 2001
    14
    hey chris,
    what you could do is go down your your local computer store and see if they have any of those computer fans, then you can put that fan on a switch or you can hook it into your power turn on wire, i would suggest the switch, and just turn it on when you turn your system on ,that should be enough air flow to keep it cool enough from shutting off.
