A little help...?
Discussion in 'Pacific Region' started by NoSmog73, Jul 14, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Here is the link Help...
    Any idea's anyone...mike
  2. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    First thing is to check fluid level. Second is to change filter and fluid. Third is to rebuild tranny.
    David
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep check Fluid level first...
  4. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I will check it after work thanks guys mucho grassass to you..David did you get the pm about the trail... /forums/images/icons/smile.gif /forums/images/icons/smile.gif
  5. Priest
    Priest Registered Member
    Apr 22, 2002
    95
    Tracy, CA
    Is temp a factor (ie. only does it when it's cold or vise versa)? Also, when was the last time your trans was serviced (filter and fluid changed). A/T's are one of those things that people often forget to service once a year (the other is diff's) and if your filter gets dirty enought it won't allow enough pressure to build up in the valve body for proper operation.
