A little more lift...
Discussion in 'The Garage' started by jms, Aug 29, 2006.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    I might need a little more lift in the rear to prevent a 'prerunner' stance...
    I just changed the front from worn TC 3" EZ to new TC 3" HD springs.
    The rear is a 2.5" ORD shackle flip and a 1" ORD ZeroRate. I also hope to have a new rear tube bumper come BlazerBash, with tire carrier and gas can.
    I could...
    1. wait until the front settles a bit; maybe not carry so much stuff... ($0... I like that...)
    2. take the ZeroRate out, add an add-a-leaf ($50 + new U-bolts) gain ~1"
    3. just add the add-a-leaf ($50 + new U-bolts), gain 1.5" to 2"
    4. add air springs ($250 or so...)
    5. replace the 2.5" flip with a 4" ($180 or so and a PITA due to the tank...)
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd run everything and see how it sits. $0 is a good way to go. If its sitting butt low in a bit, just deal until th esprings settle, still butt low then go with an add a leaf.
  3. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    What about ORD supershackles? The longer ones are 6".
  4. jms
    Jan 24, 2001
    1,683
    Hmm. Hadn't thought about that possibility. Wouldn't a longer shackle upset my pinion angle even more?
  5. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    I got a set of air bags I could make you a deal on.
  6. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    I guess it would affect the pinion angle. Hadn't thought of that.
  7. jms
    Jan 24, 2001
    1,683
    I'll get back to you for details about those airbags when I'm back from New York...
  8. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I will be ordering the super shackles for mine in the next couple days!!
  9. jms
    Jan 24, 2001
    1,683
    I wouldn't mind a little more spring rate in the back to go with the slightly stiffer springs up front, and I had thought about air helper springs before...
    The idea stems back from driving Rocker Knocker in Pritchett, and the thought that you just could inflate the driver's rear to be a little less 'offcamber' in this obstacle was somewhat appealing...
  10. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Interesting idea. I've wondered how air bags would work in offroad situations. Is this a very common thing to do?
