A Little Nervous
Discussion in 'The Garage' started by njonl, Aug 16, 2004.
  1. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    I am going wheeling for the first time in a while. I got some new tires and put em on. Last time I went wheeling, I had some less agressive 33's and now I went up another 2 inches and put on some 36's. I am running my stock 10 bolts. I don't plan on romping on it. Just some mild stuff. Any suggestions ? I am about to go to 3/4 ton in a month or so. Would anyone recommend lincoln locking the rear ? I would also appreciate any other advice offered to keep me from breaking anything. Thanks,
    -Nick
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    you getting a 14FF rear? lock it if you are, and leave the front open with the 36's. it'll last longer, if you have a stock 350, you should be fine, dont worry about the 14ff at all, its a monster, the front axle is your weak point, and if you dont install a locker there, you wont have *too* much brakeage to worry about /forums/images/graemlins/thumb.gif
  3. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    if yer talkin bout welding the 10bolt...u might as well bust out the /forums/images/graemlins/hack.gif and cut the axle in half...save yerself the trouble of doin it on the trails...a welded 10 bolt is ASKING to break axles!!
  4. njonl
    Jun 30, 2003
    128
    Northern CA
    Thanks.
