A little off subject '67 C20
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by red450ih, Mar 12, 2000.
  1. red450ih
    red450ih 1/2 ton status
    139
    Nashville, Tennessee
    A little off subject \'67 C20
    I am looking to buy a '67 Chevrolet C20 4WD truck. Does anybody know what front axle it has? What about the Tcase and trans? The rear end looks a little odd, it looks alot like a big 9 inch ford rear with full floating axles. Any info would be great.
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: A little off subject \'67 C20
    <font color=blue>If it's a c20 than it is two wheel drive. The rear is an Eaton drop-out. you can get lower gears and a detroit for it, but otherwise, I know nothing more about it except for the fact that it is really rare.</font color=blue>
  3. red450ih
    139
    Re: A little off subject \'67 K20
    It is a 4WD. I guess I should have said K20. Can I get higher gears for the Eaton like 3.55 or 3.73's? What kind of Tcase is in this truck?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I think it is an np205, but i'm not sure. The frontend is a closed-knuckle d44. You might be able to get lower gears if it doesn't have them already</font color=blue>
  5. red450ih
    139
    It doesn't look like a NP205. I have heard bad stuff about the closed knuckle design. Is this true? Actually I want higher gears instead of lower.
    Thanks for the info.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They used a Rockwell T-case in most of the '67 and '68 trucks. I think parts are hard to find for them. The tranny will be an SM420 or SM465. Reverse on the 420 is down and to the left. On the 465, it is down and to the right. Above replys on the axles are accurate, except that I don't think gears are available for the rear end anymore.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>They are a little weaker than open-knuckle axles, but they are sealed much better. Patrs are getting hard to find</font color=blue>
  8. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The transfer case is a Timken T-221. Parts are obsolete, but you can still get seals and bearings. Low range ratio is 1.94:1. The front axle is a weakish closed knuckle Dana 44. I say weakish due to the small bolts holding the steering arm on. The rear is a drop out used from 1946-1972. Gears are obsolete, you may get lucky and find some.
    ken
  9. red450ih
    139
    Well if I get the truck I want to put an open knuckle D44 or D60 in. I also thought that I would put a 14FF under the rear. I want to do this because I have heard alot of bad stuff about the early 4WD axles. Would axles from a 73-87 truck fit the '67 or would I need to find a 70-72 D44 and 14FF?
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Nope, the stuff you mention is a bolt in. Just measure the spring widths on the rear and front of that '67 and compare to the late model axles you buy.
    ken
