a little smoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by diaedy, Aug 15, 2005.
  1. diaedy
    diaedy Registered Member
    Jun 14, 2005
    19
    Ct
    Yesterday my son came home and went to start his truck when smoke started coming out a/c vent. What happed was that where he put his tack wire through the firewall it shorted out and in the process burnt through the water temp guage wire that is all coiled around the heat wire. So bad it melted the tack and water wire together. Now that he replaced them the truck WILL NOT START. Not even fire. There is 12 volts going in to dist from the purple wire but nothing coming out to plugs. HELP
    The truck is 1985 350 with the dist an coil all together.
    Thanks. Not to keen on how this dist works.
    diaedy
  2. diaedy
    Jun 14, 2005
    19
    Ct
    help
    come on guys I really need some help
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    post this in the garage, and you will get ALOT more response.
    i cant help you with your problem tho.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    sounds like ya popped a fusable link, ECMB fuse, something like that...
    does it crank?
  5. diaedy
    Jun 14, 2005
    19
    Ct
    Yea she turns over really fine. Posted this in garage and got a responce so thank for tne Insight
    DIAEDY
  6. diaedy
    Jun 14, 2005
    19
    Ct
    It was the coil . Replaced both at seperate times, both module an then coil, and that did the trick. I really appreciate the help as my knowledge is limited.
    diaedy
