A little unexpected lift
Discussion in 'OffRoad Design' started by bodacious, Feb 11, 2007.
  1. bodacious
    bodacious 1/2 ton status
    Dec 29, 2005
    296
    Quitman, Mississippi
    I just got my 1" body lift & body bushing kit from ORD. As usual, great service and speedy shipping. One of the coolest things is, when I replaced the bushings, I actually got between 1 3/4 & 2" lift with the 1" body lift. I knew my stock bushings were shot, but I did not realize that they were that bad off. Nothing like getting a little extra lift. Now I have approx. 8", and am getting 38s. :waytogo:
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I had the same experiance. It is amazing what the new bushings added.
  3. twodollars
    twodollars Registered Member
    Jul 19, 2006
    49
    Wayne, MI
    did you guys notice any more vibration passed into the body due to the aluminum spacers as opposed to the stock rubber (or urethane, for that matter)? I enjoy the ride on my burb, but want to replace the bushings, and am looking at the 2" performance accessories kit and the 1" ORD kit. I don't really need any extra lift, but need to replace the bushings.
  4. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    how do you know if they need replaced?(bushings)
  5. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    first off ( twodollers ). a 2" body lift from performace accessories is a body lift like the 1" ord kit but the ord is cut from aluminum. you would end up with 3" body and dubble stacked kits not good at all.
    second ( 53chevy ) if your truck is that old and has that many miles on it and you are asking i will bet that thay are shot. the only ones i have seen that are still good were the super clean sothern trucks or a vary rare low miles never drivin stuff up here in the north.
    for the best in the long run poly body kit and then 1-2-3 " body lift to sut your needs. cause if you do just the body lift when you pull it all apart you will need at least 1 bushing or more . then you will say to your self why didnt i just get that poly kit to start. :doah:
  6. twodollars
    Jul 19, 2006
    49
    Wayne, MI
    I guess I wasn't too clear. I was not looking at stacking the two kits, I was looking at one or the other. What I wanted was a 1" poly kit as opposed to the aluminum. The line of thought was that the poly pucks would transmit less vibration that the aluminum. But i there is not much difference with the aluminum, then that would be fine too.
  7. sweetk30
    Nov 1, 2004
    25,536
    532
    lift blocks on good mounts shouldnt pass on vibs at all. as its no diffrent than the steel body washer on steel body. when i install my body mounts i use a good coating of grease to make sure it all seats in perfectly.
  8. twodollars
    Jul 19, 2006
    49
    Wayne, MI
    Thanks - I will give the ORD stuff a try.
