a locking hitch pin and no key
Discussion in 'The Garage' started by ramjet gmc, May 25, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I just got a new truck Power Stroke 7.3 diesel Excursion but 1 problem I have a 2" box hitch with a locking hitch pin and no key I think heat is out too much plastic should I drill it out?? Have you had any luck with this ?? /forums/images/graemlins/1zhelp.gif
    <font color="red"> Well I got it off I did try some other keys I had but no luck but I did drill it out and it was so easy to do just started with 1/8 and stopped at ½ their was a small screw in the back of the lock cylinder and I drilled that and put in a screw extractor and it popped off the hole thing took 15 min thanks for everyone’s help </font>
  2. dyeager535
    26,975
    Saws-all would probably cut it quick, either that or cutoff wheel.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    high speed cut off wheel /forums/images/graemlins/thumb.gif
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Is it a factorry Ford setup or an aftermarket item?
    Either way, there should be a code on the lock somewhere that either the dealership or a locksmith can decipher to provide you with a new key......
  5. ramjet gmc
    Dec 19, 2001
    3,370
    aftermarket item?
    --- yes and looks tuff too /forums/images/graemlins/mad.gif
    cut off wheel i did not think of that anything else??
  6. Can Can
    15,552
    136
    Is there not a 4 digit code on the face of the lock near the key hole?
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'll second the cut-off wheel. I just cut a carrier cross-pin with one of those cut wheels. It should cut that pin like hot butter. I am now a believer in those wheels. /forums/images/graemlins/smile.gif
    John
  8. ramjet gmc
    Dec 19, 2001
    3,370
    Well I got it off I did try some other keys I had but no luck but I did drill it out and it was so easy to do just started with 1/8 and stopped at ½ their was a small screw in the back of the lock cylinder and I drilled that and put in a screw extractor and it popped off the hole thing took 15 min thanks for everyone’s help /forums/images/graemlins/grin.gif
  9. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    You are a more patient man that I am. I would have just kept whacking it with a BFH till it was mangled beyond comprehension, then I would have taken it over to my friends house to be cut off with the torch. /forums/images/graemlins/rotfl.gif
  10. I had the same problem with my blazer when I got it. I took a large (1 1/2"dia.) 2 foot long "chisel" and a 10 pound sledge hammer to it! It came off with the second hit. Problem solved! /forums/images/graemlins/grin.gif good luck!
  11. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Take it to a locksmith.
    A good locksmith can pick any lock in just a few minutes. Have him make you a set of keys while he has it apart and it will probably cost less than buying a new lock.
