A mess load of 6.2L problems. More and more and more......................
Discussion in '1982-Present GM Diesel' started by 84CUCV, Sep 30, 2003.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    First, I found the wiring in my 1009 is put back together with crimp connecters. I am going to solder that and use some liquid tape. I need to smack out my oil pan. SHould I repalce the rear seal while I am there? At this time it is not leaking. Last, but not least I just found out I did the head work on my truck about 5k ago with a touque wrench that is from the early 70s. Now i know why the back of my head is leaking. SH!T! Should I do the job over again or could I just use a new wrench? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif Let me know what you guys think. thanks mike
  2. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    anybody??????????????????????????????
  3. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    I might be the wrong person to ask since i am anal when it comes to repalcing things. If i had the oil pan off, i would do the rear main. why risk it its cheap to replace and only will take a minimum amount of time more. If the haead is leaking you probally already damaged the gasket, so i would replace that as well. Did you use new bolts the last time you repalced the gaskets?
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Yes, i did. I will be redoing it as soon as I get my other truck up and going. mike
