A new 203 doubler question
Discussion in 'OffRoad Design' started by Mrtlc4x4, Apr 8, 2003.
  1. Mrtlc4x4
    Mrtlc4x4 Registered Member
    Dec 27, 2001
    18
    minnesota
    It there a adapter to use the chev.203 low with a dodge 208?? and if so how makes it and how much?? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/usaflag.gif
    I want to use the dodge208 so I have a fixed yoke
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    If you find around a 1980ish 205 it will be a 32 spline input and have a fixed yoke, plus it will be gear to gear. The 208 is a piece of junk transfer case.
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I have to disagree with you bud. Given the proper protection from rocks and keeping the fluid levels correct, the 208 is a good t-case. It offers a lower low range than the 205, which may be why he's looking at it.
    Back to the question. I don't think anyone makes one of these. From the pro's perspective, the 205 is the only tcase, with the exception possibly of the Dana 300, that could handle the doubled amount of torque from the engine and tranny.
  4. Mrtlc4x4
    Dec 27, 2001
    18
    minnesota
    the fact that a 208 has 2.6 to 1 is the exact reason that i'am looking at useing a 208.plus it's alot lighter.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i think a 208 is a 27 spline.
    I know Dr. Watson can machine a doubler for all kinds of stuff. Even a few 203/Atlas II doublers out there. But IIRC, he says it's kinda pricey.
    IMHO, why not do a 3.1:1 WMS 203 mated to a NP205 for your application if you want the 2.61:1 slectability?
  6. Mrtlc4x4
    Dec 27, 2001
    18
    minnesota
    Thanks to all for the input,I'am running a 208 now with sliper have plans to use dodge output and rear half of case,to get a fixed yoke.I have a couple of friends running this set-up already.I was just hoping there was a way to add more reduction.on a budget Ohwell it never hurts to ask!! /forums/images/graemlins/cool.gif
    http://hometown.aol.com/mrtlc4x4/myhomepage/collection.html
  7. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    T-400 208's are 32 spline but the dodge ones are 23 or 24 spline /forums/images/graemlins/shocked.gif
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We've had a little interest in a 203/208 adapter and my only problem is selling something that I don't have total confidence in. It would have to be a different adapter than what we have, but it's pretty simple to do. After Easter I can look into it again to see what it would take, and look into what we can do to let a 205 interchange on the adapter later if you do have problems.
    You would definitely have to have a 32 spline 208 input gear but that's not a big deal, as mentioned, it's stock for a 400 version NP208.
  9. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    If it doesn't work out, try a NP241 from an 89-91 K5. They have a low range of 2.72:1 IIRC and are SYE compatible.
  10. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Do 89-91 subs have the 241 too?
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    They should, but only the old body styles will have the right one. The newer body styles have one, but the front output is on the driver's side.
  12. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    MY 90 SUB HAS A 241....
  13. Mrtlc4x4
    Dec 27, 2001
    18
    minnesota
    where does one get the sye kit for a 241 and how pricy are they?? /forums/images/graemlins/confused.gif
  14. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I bought mine from Jesse at www.highangledriveline.com and paid around $325.00 for it. Don't forget though that you will need to redo the driveshaft afterwards. The SYE kit shortens the T-case by about 6".
  15. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Tony,
    I friend of mine (and a member of the board) took what you're talking about one step further. He took a Dodge 208 T-case and is in the process of swapping the input shaft from the GM 208 to use behind the 700R4. He also found that by using the front half of the Dodge case, it clocked the entire assy up to a nearly flat position.
    I have a theory that this will hold true as well to the Dodge 241, which also has a fixed yoke.
    241 sye kits:
    http://www.highangledriveline.com
    http://www.jbconversions.com/pages/np241/index.html
    http://www.jeepbox.com/np231.htm
    Jeepbox used to have the 241 kit listed and was the best price I've seen. Call them.
    Stephen, are you suggesting that a doubler kit could be built with intentions of using a 208/241 but could later be swapped out with a 6-bolt (round pattern) NP205?? That could be interesting.
  16. Mrtlc4x4
    Dec 27, 2001
    18
    minnesota
    Tony,
    241 sye kits:
    THANKS!! /forums/images/graemlins/grin.gif for the Info and the thery,I will now be looking into that process too.Any idea on if there is much machining to instal the gm input into the dodge??
    Please keep me aprised of the progress on your buddys swap I will do the same if I make progress!!
    Again BIG thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif to all for all the great feedback.
    Tony
  17. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I need to measure up a 208, I know it'll bolt to our current round pattern 205 adapter but I think the shaft configuration is different. It might require a spacer or different adapter.
  18. Mrtlc4x4
    Dec 27, 2001
    18
    minnesota
    I picked up so cores to day. a dodge 241 a chev 241 and a couple of 203s one for a th400 and one for a th350
    I starting to think that I can make the dodge out put owrk on the chev 241 so that fixes the yoke problem.
    Now i just have to start reading previous post and "learn myself up" the ins and outs of the 203 low range.
    I'am looking forward to hearing what you come up with.and even if you (ORD) decide not to go down the avenue of the 203/208or241 doubler.I will still have learned something new!!
    Thanks--->
    Tony /forums/images/graemlins/smile.gif
