A new Place to look for frame cracks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Apr 10, 2006.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    SO, I was unbolting the last two bolts on my tranny x-member and bang, it hits the ground. What the hell?
    I looked up at the frame:eek1:
    Yup, its cracked. I found this discovery very strange being that this was and has been a stock truck with the 305 and OD tranny with 31" tires its whole life. And very rarely offroad at that....this is on a 1986 Blazer
    Looks like I have some welding to do....
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Great post. A lot of us out here probably wouldn't think to check there for cracks. I had that happen on a previous K5. I just made up my own repair like you are gonna do. I wonder if boxing the frame would be a good idea? Good luck in your repair.
  3. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Was anything else wrong that could have contributed to it?
  4. dyeager535
    26,980
    Obviously not a common problem, but I wonder if that didn't/doesn't happen because the later truck crossmembers moved the bolts so close to each other compared to all previous.
    You can see on the crossmember the "outboard" bolts, that's about how far the earlier crossmembers spaced them.
  5. koldsimer
    Jan 10, 2005
    1,480
    texas
    That would make sense huh? I didn't even notice how close the holes are until you mentioned it.
  6. dyeager535
    26,980
    As an aside, it was a stock truck, so were those metal spacers on the bolts as well? (still no idea why GM started using them)
    Any evidence that the bolts had been loose previous to you taking it apart, and had been allowed to hammer the frame constantly?
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    The metal spacers are to enable use of a longer bolt. Short bolts don't hold troque very well. The longer the bolt, the more it will strectch during torquing and hold that torque better. This is vastly more important on 'critical' bolts, like the ones holding the steering box to the frame. Those have long metal bushings on them as well.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I've seen a couple cracked around the trans crossmember. Also, if you want to look for more cracks, I've seen more cracks around the rear shock mounts than the trans crossmember. In the past couple of months I have seen probably 4 trucks with either a crack, or a repaired crack on the rear shock mounts on the frame.
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I had to repair my frame back there.
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    Nope, the bolts I bet had never been loosened, the previous owner drove this truck as a work truck from 86(new) to 88 then bought it from his company and I have a file folder 4" thick with routine maint from 88-04 when I bought it. The guy didnt hunt and had maybe taken it offroad a handful of times, with 120K on it....drove like a caddy...my theory is the same as:
    I plan on using my old crossmember anyway. I really think the close spacing and a bad tranny mount could do that.
    Just a little suprise...:rolleyes:
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Do you have the cross member that ties to the upper and lower c sections of the frame. I've seen some that just bolt up to the bottom. If yours' just ties to the the lower section, I would probably go to the junkyard and get the other type that has a branch to tie into the upper frame section as well.
  12. BowtieBlazer
    Jul 15, 2001
    2,462
    I've seen that type but only on older trucks. I will more than likely box the frame in that area either way
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Might wanna drill a hole at the end of that crack too:D
  14. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Correct me if i'm wrong but it looks like you did the old drop teh t-case by putting the spacer between the crossmember and frame trick. Right? I've seen this in several trucks in our club, The spacers localize the stress around the bolt hole leading to the cracking that you have, you shouldn't need to totally box the frame, do a good repair. Maybe even plate that area, but when you put it back together use square tube or a solid block of steel or even a stack of 1/4 plate instead of the spacers to spread the load out over a large portion of the framerail.
  15. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    He said it was a stock k5 on 31's.
  16. RaisedK5
    932
    Long Beach, CA
    Now that i look at it again, i guess my eyes were playing tricks on me i thought it looked like the spacer was between the frame chunk and the crossmember.
  17. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I had to look twice too:doah: :D
  18. BowtieBlazer
    Jul 15, 2001
    2,462
    nope, the spacers were on bottom
  19. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    My 86 cracked there too. After I repaired it. I used some large flat washers to spread the load.
    John
  20. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Just looked at a neighbors '86 3/4T 4x4 Burb. One owner little old lady from Florida, so no rust. LR shock mount broken right off! Client has a '90 1/2 V6 5 speed 4x4, LR shock mount rotted off, and cracked, but rest of frame not too bad...
