a newbie question
Discussion in 'The Garage' started by dammit32, Aug 26, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    whats a divorced transmission? i see this alot in the stuff i read about doublers and have no clue what they are referring to /forums/images/icons/frown.gif
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You mean a divorced transfer case. Just means the transfer case isn't directly bolted to the tranny. It is instead seperate and connected by a driveshaft.
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    if you just have a curious question, as all newbies do, like 15 a day, id try search at the top, itll show you all posts on that topic /forums/images/icons/laugh.gif
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    There are also divorced transmissions where the motor and the tranny are at different ends of the vehicle connected by the driveshaft, like the porsche 924 but uncommon in trucks outside of custom creations.
  5. Grim-Reaper
    7,385
    Atlanta
    C5 Vett has a Divorced Tranny. GM also built a couple cars in the early 60's that the tranny was in the rear so they could have a lower floor. I think it was a Pontiac. Had independent rear suspension also. I think that was the car that had the "rubber band" drive shaft. When the car was just sitting the drive shaft drooped down but once under torque it pulled back in line.
