A question about driveshaft angles
Discussion in 'The Garage' started by Eric M., Aug 12, 2005.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    We're talking rear driveshaft here. I know the angle at the transfer case should match the angle at the rear pinion, BUT, what happens when you have a 2 piece rear driveshaft with a U-joint in the center? Does it matter where you position that joint (up or down)? Any angles you have to consider here?
    It seems that regardless of where you position it, you will be introducing some sort of vibratio as the suspension travels up and down as you do not have a 4th U-joint to cancel that one.
    Anyone??
    Thanks,
    Eric M.
  2. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Oh come on ..... no one??
    Where's Jess?
  3. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    you have a pm!
  4. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    Eric, any good answers on this? I have a vib in my crew cab that I'd love to fix. :crazy:
  5. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    This is what I got from Jess when I called him. He was going over it pretty fast and I might be leaving out a few points. He said all set ups are a little different, but, here is the BASICS for the split rear driveshafts.
    -The shaft leaving the transfer case (or tranny in 2 wd set ups) wants to be pointing down 2 degrees more than the output shaft of the transfer case (or tranny).
    -The pinion angle of the rear dif. needs to match that of the first driveshaft, NOT the output shaft of the transfer case as is the case with a single driveshaft set ups.
    There's the basics. Get out your angle finder and check those angles on your crew cab!
    Good Luck,
    Eric M.
  7. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    EXCELLENT info! THANKS!!!
