A Question about gears
Discussion in 'The Garage' started by Eric M., Jul 16, 2005.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Are front and rear differential gears cut the same? Example - are a D60 front and D60 rear gears interchangable, or atleast the same cut?
    What are reverse cut gears and when / where / why are they used?
    How do high pinion gears (like a Ford D60) differ from from standard gears (GM D60). I know the pinion is higher, I want to know how the gears or cuts of the gears differ.
    Thanks,
    Eric M.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Reverse gears :
    Some manufacturers did that so the front axle wouldn't be technically driving in reverse as the truck goes forward . Keeps the coast and drive side the same front and rear I believe .
    On most GM trucks , due to being cheap , and they figured we'd hardly use em in 4wd as often as 2wd , they didn't bother the expense of reverse cut gears .
    The actual D60 questions I do not know , don't have one , people wanting them priced us regular folk out of the market .
