A scarry thought
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2cocky, Oct 26, 2001.
  1. 2cocky
    2cocky Registered Member
    Oct 7, 2001
    59
    Southern Maryland
    I was pulling the rear carpet to get ready for hurculining the interior this morning. When I got to the front drivers seat I pulled off the seat belt mounts so I could remove the side trim panels. Well when I went to remove the bottom attach bolt for the seat belt the whole thing pulled out of the metal!! I am a Firefighter and EMT and the tought of a chunck of rusted metal ripping acrost my adomond when Joe Yuppie in his Excersion pulls out in front of me scares the hell out of me! Any ways I'm looking for ideas on how to fix this. The whole panel where the lower mount attaches is rusted out. Is there a way to repair this area with enuf strength to attach the seat belt to? Or should I just use this as an excuse to get a roll bar installed?
    Sorry for being long winded. Let me know what you guys think.
    Scott
    OOOPS....I THINK I JUST RAN OVER YOUR JEEP THING!!!!!
  2. J.R.
    J.R. Guest
    i would go with the roll bar. as you know it's far safer and it looks soooo cool!! but be sure to fix the rusted area the right way or you will be doing the job all over again in a few years.
    BIG BLOCK MAN
    "MORE POWER"!!
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Repair the section and then get a roll cage.. The cage is far safer in a roll pluss you can get 5 point harnesses and that you hold you still more in a crash...
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  4. 2cocky
    Oct 7, 2001
    59
    Southern Maryland
    Ok so I should go with the rollbar after I fix the rust spot. Where can I get a roll bar/cage that allows easy axcess to the back seat? Who makes a good strong cage? and who's is the easyest to install? thanks again
  5. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    it does sound like a good reason to get a roll cage. my 84 was the same way. i thaught i was being a good masshole always with the belt on. turns out the only thing holding it there was the cardboard carpet backer
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Smittybilt makes a bolt in roll bar, but it bolts to the floor. You would have to make sure the floor is strong and not rusted... You also may want to check with your local fab places about making you one and then tying it into the frame. That would be your best/strongest bet..
    Although you could also go to a auto body shop and see what they would charge for fixin your hole where the seatbelt mounts...
    Mike
  7. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    Mine was the same way, don't have the time or money to upgrade or fix right now so what I did.... I placed two pieces of plate steal on either side of the floor and bolted the seat belt down their.
    I know it's not the correct location but after the wife went on a 16 hour road trip with me and we noticed only the carpet holding the seat belt down I had to do something.
    New floors, side panels, and rockers will hopefully go in this winter. Just waiting for possible job change and relocation.
    Gone Large and Loving It.
    Keith
    Manchester, MI
  8. Grim-Reaper
    7,385
    Atlanta
    You can mount off the roll cage very close to the original seat belt mounts. I did it this way on my 75 since I wanted to get shoulder belts and with a removable hard top there was no upper location to attach the shoulder strap. I have 2 kids and the cross bar needed for 4 or 5 points was going to be an issue getting the kids in the back.
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i would get a fabbed cage with mounts inside the cage for seats &amp; belts. In my experience, it is better to go all the way with a mod than do only do a bit, half way or the cheap route, and find out later it would have been easier/cheaper/better to do it right the first time (e.g. my driveshafts, rear lift, rear seat, etc.) I have made some questionable repairs &amp; add-ons but nothing is more important that safety. Just MHO.
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  10. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I agree. Cage it, tie the cage to the frame and the seats/belts to the cage. Pretty foolproof.
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  11. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd definitely go cage - Harnesses do bear a safety issue on the street though. In the event of a side impact, there's no way to lean toward the inside and avoid any passenger compartment intrusion.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  12. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    If you want to see how I fixed my area, I have pics of it that I just did. Check out <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a> and You'll see how I fixed your exact problem.
    Ben 87 Jimmy
  13. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Thats a really cool site and a great truck. The only b*tch I have is that maybe you could break down the photo pages because it takes a long time for us with the slow-mo 56k modems.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  14. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Thanks very much for the comment Blazer Boy. I really take pride in my truck and I love hearing people who like it. Sorry about the website being a lot for you to load, so if I just take some pics off the page and move them to my next one, I'll be all set?
    Ben 87 Jimmy
