A seemingly unconquerable problem
Discussion in 'The Garage' started by Atom Eyes, Aug 27, 2006.
  1. Atom Eyes
    Atom Eyes Registered Member
    Apr 30, 2005
    16
    Philadelphia, PA
    My one-owner '89 K5 has 173,000 happy miles on its original TBI 350/700R4 drivetrain. Aside from my ongoing rusty body panel replacement program, for the past couple of months I have been experiencing a really irritating hesitation/rough idle problem which was so bad at one point that the truck was virtually undriveable, a radical departure from its normal silky-smooth, fast accelerating history. First, I did a full tuneup, adjusted the timing and replaced the EGR valve and fuel filter. A slight improvement. Then one spark plug was found to be cracked and was replaced. When she started acting badly again, some vacuum lines were replaced. This finally alleviated the rough idle. Again, she was okay for a couple of days until the exhaust pipe (I still have a single exhaust, can you believe it?) was found to be rusted from the cat back and was replaced. I figured the hesitation came from a backpressure problem and was surely solved now, but it still persists. I don't know what else I can possibly replace now. Any ideas?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Check fuel pressure. And for vacuum leaks at the intake/throttle body. Any codes coming out of the computer?
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Definitely check for trouble codes and hook up a vacuum gauge to see if the needle does anything unusual. Ditto on the fuel pressure as suggested some moments ago by my distinguished colleague.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Did you disconnect the EST wire when you timed the rig? Also fuel pressure check should help alos like was already said. It is possible for the fuel pump to be dying on you after that many miles. Mine was having similiar issues and once i replaced the fuel pump troubles were gone.
  5. cutlass350
    cutlass350 Newbie
    Jun 20, 2006
    Knoxville, TN
    When you did the tune up did you put on a new cap and rotor? I went through all the same things at about 130,000 miles and my dumb ass didn't replace the cap. One day I washed my truck and it ran so bad it wouldn't even pull out of my driveway. Once I replaced the cap it obviously ran much better.
  6. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I'll bet your catalitic converter is plugged near solid...if you have one.
