A series of questions, a la K5 Blazers
Discussion in 'The Garage' started by Vetteman61, Feb 28, 2007.
  1. Vetteman61
    Vetteman61 Registered Member
    Jan 11, 2007
    93
    Kentucky
    After installing my lift (4" springs up front, blocks in rear), I have a popping noise when I take off from a stop or during weight transfer during a turn. Has anyone experienced this and maybe lead me in a direction to start looking.
    Where do most people run their breather hoses for the transmission and differentials? If I extend these high enough, will I be set to hit the creeks as deep as my breather hoses (or air intake) will allow? Do I need to do any other preparations to do some aquatic submersions??
    I'm planning some custom radio installation work, adding a radio in front of my cup holders. Does anyone have a junk or extra Gray center console (or even just the front half of one)?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I would bet that the popping noise you are hearing is your u-joints being loose. Check them ASAP.
    Extending the breather hoses shouldn't change much about whether your rig can ford water or not. Water can get into the diff from all kinds of places and water contamination will wipe out bearings pretty quick. If your diffs become submerged in water either check the fluid for contamination or change the fluid very often.
  3. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    I've got an extra gray console, '81-'91 type, where in Ky are you?
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    x2 on the u-joints.
    also, make sure your slip yoke is not binding. it doesn't take much spline wear to allow unwanted motion, and since the lift has pulled it farther out, you now have more force applied to a smaller area. have you checked driveline angles?
    on the radio, i assume you want to install the head unit in so that the face is straight up and the cd loads vertically. i know some are made for that, but it's been my personal experience that most don't love that position and will skip easily.
  5. 1977k5
    May 26, 2003
    9,992
    130
    Wow, I actually meant that your u-BOLTS are probably loose.
  6. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    i run my tranny breather up and around my brake booster. Im about to lengthen my diff breathers more, fronts will go towards the top of the core support and my rear i will put up into a fender well.
  7. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    I'm in Bowling Green, Kentucky. Are you in Plano, Texas?
