A short maiden voyage!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Yukon Jack, May 10, 2005.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Took half of yesterday off and got my front shock towers installed and the front shocks installed. Then I proceeded to finish my home built power brake bleeder and bled the brakes. What a simple, cheap tool, and it worked awesome! Flushed all of the old fluid out and it is definitely a one person job using the power bleeder!
    Got a little brake fluid on a rim so I figured it would be easiest to fire the truck up and get out of the barn to wash the rim off. I don't have a steering column installed but was able to get out of the barn easy enough. After I got the rim washed off I just had to try to go for a drive.
    I got the old column and connected it to the steering box loosely and threw on a spare steering wheel and fired the truck up. I had to drive holding the column up but I was able to drive to the end of the drive and back, probably 1/4 of a mile. I was all smiles.
    Found a small leak in the high pressure line going from the steering box to the hydroboost so I got it pulled last night and it is having a new hose installed today.
    My oldest daughter asked this morning when I was going to be able to take them to school in the truck - maybe if things go well I can before school is over this year.
    A bit more to do but I'm getting so close!
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    YYYYYYYYYYYYEEEEEEEEEEEEEHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAA!!!!
    Great stuff!
    Man I am so close to driving mine I can taste it....
    What is the info on your homemade bleeder??
    Congrats
    Burt
  3. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
  4. Burt4x4
    6,854
    OH cool, push that fluid thru.
    I have a hand held pump that pulls the fluid thru. Mighty Vac or something like that. I have had it for some years now. IT seams to work ok but I do have to trim the hose from time to time as it doesn't always seal on the bleeder screw.
    Thanks for the info
    Burt
  5. Bob87Burb
    Bob87Burb 1/2 ton status
    Apr 19, 2003
    141
    RI
    Looking great! It's also a great thing when the kids ask to go for a ride. Of all the cars we have, my kids like the rusty old Burb the most. Yep, I'm raisin' em right. :)
    Good luck with getting it finished! It would be cool if you could take them to school (maybe on the last day?) in the newly finished rig.
