A stall, a wide open throttle, a novice mechanic...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Jan 17, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Once again id like to thank you guys for all your help and tolerating my countless sometimes ridiculous questions.
    Today after school i was pulling out and as i got on the road I just floared it for fun. It went for a second then just died with a little pop. May have been a back fire. I got on some back roads tried the same thing died everytime.
    Also of note somoetimes in the morning it stutters a little till it gets warmed up.
    I think the choke might not be opening all the way and that might be it. Any help would be apreciated.
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  2. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I don't think what you said what you are running for a carb.?
    9/11/01..Never forget...Never forgive
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Yup, I agree with the above statement - What kinda carb you runnin'? I would guess its a Holley with a bad power valve. [​IMG] Mine is doing the same thing. Romp on it, and it falls on its face. But if you feather it, she still takes off just fine.
    I wish I could find the adapter to install my QJet... [​IMG]
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    FYI
    Edelbrock maks adapters to install Q-jets on a square bore manifiod.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Try advancing your timing a bit. Well I guees it would depend were it is set now. if you have it at 4 move it to 8 or 10.
    Could be the carb, could be gas filter getting full and when you hammer it the sucktion and crap block the fuel.
    Did it pop out the carb or out the tail pipe?
    If I remember corectly, if it backfires out the carb then it's ignition issue of some kind. If it backfires out the tailpipe then it's a carb issue.....or did I get that backwards????[​IMG]
    anyway GoodLuck
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
