A-Tron; More Quality Parts/Work... A Dodge Dana 60 Front Solution!
Discussion in 'The Garage' started by Swanson52, Mar 14, 2003.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    With the growing price and shrinking supply of GM Dana 60's, many GM enthusiasts are turning to Dodge for the answer; the Mopar fellas seem to have put more Dana 60 front axles in their rigs, and the supply of them is heartier than the GM. What good does this do the GM fullsize wheeler? The Dodge 60 front shares many of the same major dimensions and parts as the GM 60. The Dodge axle is roughly 2" narrower, and when bolted into a GM truck this equalizes the track width front to rear (at ~67.5"). The only problem when installing the Dodge 60 is the spring perches. The spring perches on the Dodge 60 are roughly .5" wider than GM's. Moving the perches is not really an option for most, as the passenger side spring pad is cast into the differential housing. There are ways to get around this, the primary being just prying the front springs apart to 'make 'em fit'. Enter A-Tron. The Arizona based company who has been producing top-notch GM truck parts came to the rescue! I sent an email to Sean at A-Tron, expressing my concern about the spring perch differences, and we brainstormed some remedies. I recalled a conversation with mj about maybe machining aftermarket bushings to move the spring pad mounting width out .5". This can be done with aftermarket springs on a GM, as the aftermarket pieces are 2.5" wide versus the 3" wide stockers. The difference in width is taken up by the bushing outer on each side. This also allows wheelers to use the Dodge spring plates that came with their 60, rather than try and round up scarce and often costly GM spring plates.
    I ran this idea by Sean, and he was all for it. I ordered up a new set of Skyjacker bushings for my springs, and shipped them off to A-Tron for machining. Here is what A-Tron did:
    Here are the bushings as I recieved them from A-Tron
    Here are the individual pieces. The difference between the machined half of the bushing (bottom) and the unmachined half (top) are clearly visible. The white piece is the spacer to be placed on the outside of the thicker bushing to move the assembly outward. The inner spacer is constructed of a material similar to plastic or polyurethane, yet far more durable; UHMW.
    Another of the pieces.
    Here is how the kit will fit together, with the machined bushing on the outside of the spring, and the thicker bushing and spacer on the inside of the eye, thereby moving the spring outward the necessary .25" per side to match up with the Dodge perches.
    Additionally, A-Tron machined the ID of the bushings to accept a greaseable bolt and sleeve.
    I have to commend A-Tron on the quality of work that went into these, and on their willingness to help. Sean listened to what I needed, and we together came up with a great solution (although I stole the idea from mj /forums/images/graemlins/wink.gif ). I could not have asked for better service; to top it off, the turnaround was 1 week from the day I sent out the bushings to the day I got them back. Now that, my friends, is first rate service!!
    The bushings have not yet been installed and run yet, but I will update with how well they work as soon as possible. I would like to thank A-Tron and Sean again for the great service, product, and work quality that I have recieved!!! /forums/images/graemlins/thumb.gif
  2. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    FYI, the material we used was UHMW
  3. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Now that's what I call Built Not Bought!!!! Nice bit of work, good idea MJ! /forums/images/graemlins/thumb.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    how much for a set?
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Very nice!!
    Rene
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sweet! /forums/images/graemlins/thumb.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    At first when I read the thread title, I was assuming you had Sean machine you some zero-rates with the bottom holes offset 1/4" off to each side to compensate for the Dodge D60's.
    Needless to say, I was amazed at the bushing idea and the work they do does not surprise me at all. Very top notch and excellent craftsmanship goes into everything that comes out of A-Tron!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    how much for a set?
    A-Tron is doing it for $60, you supply the bushings.
  9. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    We had actually considered that initially, but thought this might be easier and more cost effective. /forums/images/graemlins/thumb.gif
  10. 45acpJr
    Jan 7, 2003
    632
    Tucson, Az
    Actually that was the first idea we talked about, I think MJ's bushing idea was better, simplicity is always the best route.
  11. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    Hey man those look sweet but they are going to look better when they are under my rig! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    can't wait to see the installed pics
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    oh 'mister hilift installer' changing his tune? LOL
  14. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    That is slick! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    /forums/images/graemlins/thumb.gif Thanks for the idea!!!
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I just hope it works out.
    I never really decided if it was snag-free, it just seems the path of least resistance.
    Could you please PM or email me a link to the install thread when you get one going.
    good choice of shop to do the deed.
  17. 45acpJr
    Jan 7, 2003
    632
    Tucson, Az
    Tim,
    Any word on these bushings? Did it work? Let us know. /forums/images/graemlins/thumb.gif
  18. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Everything is hanging out in my garage.... /forums/images/graemlins/crazy.gif It refuses to install itself. /forums/images/graemlins/grin.gif And I thought A-Tron could do anything....sheesh. /forums/images/graemlins/cool.gif
  19. 45acpJr
    Jan 7, 2003
    632
    Tucson, Az
    I forgot to include motivation when I packaged it? /forums/images/graemlins/blush.gif If you payed for the $50.00 upgrade we would have included a mechanic in the box *patent pending* /forums/images/graemlins/rotfl.gif
  20. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    SO, Do you still have to grind the dodge calipers to fit a 15" rim?
    Does the Gm brakes still mount up , brake lines?
    What are the differences besides spring perch?
    Driveline and ujoints still the same?
    And what are these dodge D60's found in?
    Just courious?
