A very interesting problem...
Discussion in 'The Garage' started by RustBuket, Nov 10, 2006.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm sorry to post this here, its really here nor there about K5's but you guys always have some good ideas when it comes to fabbing stuff.
    Here's the deal:
    I'm currently in engineering and am now in the process of building a small steam condensor to test the effect of steam velocity on the convective heat transfer coefficient. Anyways the the problem is I already have all the copper(and it was mighty expensive!!!) so I'd like to use what I have already.
    I have 3/8" copper soft line and 2" copper hardline. The condenser calls for the 3/8" copper line to be coiled inside the 2" about 15times.... :confused: I've been staring at the stuff and its not as soft as I was hoping. I'm really worried I'm going to kind the crap out of it and have to buy more stuff.
    I was considering a few ideas:
    1) A small pipe bending tool similar to a brake line too.... Do they have these in a 1" radius?!
    2) Annealing - can I anneal the copper so its softer and easier to work or will this just make it kink more? Any good methods to anneal?
    3) external spring - some kind of tool you slip over the copper to prevent the kinking... anyone have any info on these?
    Anyways, I'm just wondering if this is possible or do I have to go buy 1/4" copper and change all my adaptars etc?
    Thanks in advance for any suggestions.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you might be able to find a tubing bender that will be able to produce a raduis that small with out kinking, i would not try and aneal the copper that will just cause more kinking, one method that might allow you to get a coil is fill the tube with sand and block the ends you can then wrap it around a object the shape that you are looking to produce, this sounds like a pretty intresting project, im currently a engineering student myself
  3. RustBuket
    Feb 21, 2003
    1,618
    Thanks for the quick response! Sand or something like that was another option I considered, I was just worried that I wouldn't be able to get it all out.... any thoughts?
  4. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Ok here is how the ole boys do it for stills!
    Fill the copper tube with sand this keeps the tube from kinking in on itself. Heat the tube and slowly bend it this takes some getting used to to do it and DO NOT RUSH! It will take several times of heating and bend to get it right just take your time.
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    with a little compressed air im sure that you will be able to get all the sand out, you could also flush it to make sure all of it is out
  6. RustBuket
    Feb 21, 2003
    1,618
    Ok thanks guys! sounds like I should be able to do this if I just take my time and think ahead. I'm really liking the sand/heat idea. So do I need to solder caps on the end to keep the sand in or just crush them shut?
    Also, I like your thinking on the still idea! Hahaha, this project might have to become dual purpose... lol
  7. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    They make a spring tube pipe bender that works ok. I have one in the garage. It was a couple bucks from the tool shop. dont knoe how it would work on copper but I think I bought it for that kind of material.
  8. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I've heard of that "internal spring" tool also....
    Just a long section of spring material that will bend to form the curves, but is too rigid to allow kinking.
    Once you're done with the bending, you simply draw it out one end and you're finished. Clever and simple.
    :usaflag:
  9. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    The old timers used to just pinch one end but if you have caps put on on end and solder that and other leave open (cover with tape or wood dowel ). The key is go slow!
  10. RustBuket
    Feb 21, 2003
    1,618
    Thanks for all the advice. Now i can sleep at night knowing I didn't waste a whole crapload of money. Ha!
  11. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I've used those spring type benders that you slip on the outside of the tubing before. I've always had success with those, nice and simple too. Works good for the small tubing sizes like 3/8. Don't know if you can do a 1" radius with it though, that might be pushing it.
  12. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Still making 101.....I love this site!!!
  13. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    i thought
    it went inside the tube, how can it keep it from collapsing in, if spring is on the outside?
  14. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    We use glass bead from a sand blaster or playground sand with "DC plugs" in the ends. Wood cones.
    Definitely anneal the stuff and go slowly. You should be able to keep it under 8% out of round.
    To flush, run 3 line volumes of system fluid or grade "B" water thru at system pressure. A SAT flush will have no discoloration, oil, sediment, or suspended solids w/a turbidity of <.1% chlorides. (I think.)
  15. Slapperbar
    Nov 29, 2005
    2,747
    3
    To collapse the tube needs to expand somewhere.
  16. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    First you need to anneal it then fill it with sand solder caps on the end. (drill a small hole in the end of the caps) Use a wood bat or a wood dowel to bend it around, with a litttel help from a torch..
  17. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    You've never seen the outside ones? They're a lot easier to use. They only need to be about 8" long or so, and you can do as long of a tube as you want, without losing track of where your spring is inside. But yeah, if you look at a kinked tube, it'll be wide at the kink. The outside spring prevents that.
  18. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    when you anneal copper you need a carborizing flame don't you? black smoke out the torch and on the metal then wipe it clean
  19. Slapperbar
    Nov 29, 2005
    2,747
    3
    Soot the tube up and then use the carborizing flame to heat the tube up to remove the soot. So, soot it up and then burn it off. That way you get about the right temp.
  20. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    After you have the tube coiled you will need to run it thru cool water and out to the jug. Oh wait! Thats for making sour mash! :whistle:
