A very stupid pinion angle question...
Discussion in 'The Garage' started by mikey_d05, Mar 26, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm nearing completion on my rear axle swap and I have a REAL dumb question about pinion angle. I know what the proper geometry is for a non-CV driveshaft, my question is...is that so it doesn't drive you crazy with poor manners...or do it doesn't eat pinion seals and rip itself apart? This will be a 100% trail truck and trailer queen so it will only see over 40 mph very very rarely. It already has 39.5" boggers so it's gonna suck on road no matter what. I can handle vibration since it's a stripped trail rig, but I don't want to be leaking gear oil all over because my truck eats pinion seals for lunch.
  2. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    You match angles so it doesn't vibrate which can lead to premature seal/ujoint/spline failures. The speed to worry about is not truck speed but driveshaft speed and that depends on differential gear ratio.
