A winch question...8274. No it's not, it's an 8000i. OOPS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Sep 28, 2000.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    A winch question...8274. No it\'s not, it\'s an 8000i. OOPS
    Well guys, it looks like I'm going to begin designing my front and rear bumpers since that'll be a free upgrade and I'm broke. Damn k5....but great k5 [​IMG][​IMG]. And I want a front winch. I see all of you guys usually have around a 9000 lb winch, but will the 8274 8000 lb one work? My father has had one sitting in the box in the floor of the shop for about 4 years and I'm sure I could persuade him to sell/barter/finance it to me. The numbers work up to roughly 8,000 pounds on first wrap, 6,000 pounds wound up. That would put me at 12,000 to 16,000 pounds on a double line pull. I really don't want anything to winch myself through surprise canyon...(yet)...but just to get my beast unstuck when I really need it. Probable plans upon graduation would be buying a XD9500i and placing it in front, and mounting the 8274 in back. Tell me what you think. Worth it or not?
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blaze- 350/350/203, 14B w/detroit, D44, 4.11s, 4" susp, 36" TSL
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Re: A winch question...8274
    The 8274 is one of the greatest all time winches. The only thing I'd be concerned about in a front mount application is the blocking of the radiator, as the 8274 stands pretty tall compared to the new low-pro winches.
    ken
  3. laketex
    6,220
    North Texas
    I've done a little looking at magazines since I made that post, and while I see limited use of the 8274 on fullsizes, I think i'd be ok....And I do see what you're saying about the airflow issue. But I don't even have a grill, I'm sure this will help the cause won't it?
    Bryan aka LT aka Cap'n.
    haha
    [​IMG][​IMG]
    Durant, Ok
  4. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Hi there
    I have an 8274 on my Jimmy and the only problem I have with it is keeping it supplied with amps! As long as you can feed it, it will pull awesome. Add to that a doubler and she should tug your blazer out fairly easily. Of course a little handiwork with the Hilift always makes things easier for the winch in any situation.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  5. laketex
    6,220
    North Texas
    I have an optima red top. What batteries do you run? If I get the winch, I'll probably get a second battery, yellow top more than likely if the two of them are compatible.
    [​IMG][​IMG]
    Durant, Ok
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have an 8274 on my K5 and I think it pulls just as good if not better than the warn 9000 worm drives. I do run double battery's, red top for truck, yellow top dedicated to the warn. The coil speed to wind it back up is also a big plus.
  7. laketex
    6,220
    North Texas
    Well dang it, I just found out it's an 8000i. I was told 8274, but he was wrong. Any opinions on this one? I don't even know if warn still makes it. Thanks.
    bryan
    [​IMG][​IMG]
    Durant, Ok
