AA NV4500 - Slave Cyl Question
Discussion in 'The Garage' started by rcamacho, Oct 2, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    My slave cylinder blew out on my last trip offroad. The previous owner installed a slave from another application, so I'm installing the correct bracket (AA GM SLAVE CYLINDER BRKT. P/N: 715535) to addapt the stock 85-91 slave cylinder.
    Q: Is this the preferred method? Seems like it would be desirable to have the mc/slave a matched combination which they will be. Any issues with header clearances?
    Added pics.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    The AA bell is set-up for some Jeep slave. I can't recall the exact application off the top of my head, but I have one ordered and also have the matching clutch master and line coming too. Might take a bit of figgering to set-up the stroke depth coming off the clutch pedal...
    We'll see how that all goes I guess.
    Rene
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Updated with pics,
    Here's the setup from AA that I'm going to with the stock GM slave:
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    Update 10/9:
    I've received the bracket and have mocked up the stock slave cylinder. The rotation built into the adapter places the bleed screw into interference with the block when mounted upwards, downwards would prohibit bleeding. I'll post pics later on.
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    10/16:
    I've completed installation of the stock slave cylinder, pressure hose and AA bracket. Clearances from the slave to block are tight but otherwise it appears to work fine.
    Thanks to CK5 for tips on bleeding the clutch slave. I ended up bench bleeding the entire system off the truck.. It saved me lots of aggravation under the truck.
