AAAAAHHH FRICKIN BRAKES!!!!!!!!!!!!!!!!!!! NEED HELP ASAP!
Discussion in 'The Garage' started by muddysub, Feb 6, 2003.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ok i just replaced my calipers and pads on the front. bled the brakes 5 times and the pedal still goes all the way to the floor when i try stopping the suburban. there'e probably 3-4" of dead pedal before pressure builds up enought to stop it. whats going on?? what am i doing wrong?!
    i've got everything tight with all the brass washers in place and brand new pads on brand new calipers.
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    You didn't mention the rear brakes. Even if you didn't touch the rears you need to bleed them also. Also how is your master cylinder? Are you bleeding them correctly starting with the passenger rear then drivers rear then passenger front then drivers front.
  3. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    your brand new calipers were full of air. now its all in your system. you need to bleed system completely. starting at master cylinder then going to each wheel starting with the one farthest away from the master cylinder
  4. muddysub
    Jun 23, 2001
    10,451
    489
    well thats lovely. i guess i'm drivin the furd to work tomorrow, and tomorrow i'll bleed the whole frickin thing. thanks guys.
