Aaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!! !!!!!!!!!!!
Discussion in '1936-Present Suburban' started by muddysub, Sep 28, 2005.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    im gonna dig a big hole and bury this damn suburban!!! i decided to get it out of the backyard yesterday and run it a little.... and the damn thing isnt getting fuel!!!!!!!111!11!1one!!!111eleven! the injectors are new, the tbi is freshly rebuilt, the pump and filter are both new... all i can think is maybe in the last 3 months sitting in my yard the fuel varnished already... anyone got a complete TBI fuel system they wanna donate to me?
  2. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    Have you thought to see if the fuel pump relay is getting ign - batt power...and or installing a jumper wire to see if you are geting power to the pump?
    DW
  3. muddysub
    Jun 23, 2001
    10,451
    489
    i know the pump is doing good... it ran for a while, then just quit... it'll run as long as its getting another fuel source (gas out of a corona bottle, brake cleaner or something of the sort...)
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    It's just mad at you cause you want to sell it :p:
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Well i don't have a TBI setup i can donate to you, but i WILL however let you donate the Burb to me,,, for further inspection and toying with :D
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Scott, have you pulled and drained your tank? I bet you have sediment in your tank and is clogging the fuel line that runs forward.
  7. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
  8. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    mybe a fuel line clogged or your fuel evaporated away or its a pita burb like mine :D
  9. muddysub
    Jun 23, 2001
    10,451
    489
    yes when i replaced the pump i pressure washed and dried the tank for 24hrs... my pump is in the tank... the wiring is fine... im not too concerned, im moving to my new house this weekend and ill have a 1600ft garage to scatter the engine in. the motor will be coming out and everything will be rebuilt or replaced... i know something is clogged, just not sure what.
  10. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I just went through this with my truck. It would start and run about 10 seconds then die. If I tried to restart it, It would fire right up, run 10 seconds then die. Turns out the new pump would develope the pressure, but not enough volume. When I hooked a pressure gauge inline it would start out with 12-13 lbs of pressure, then I could watch the pressure fall of until it died. After replacing the fuel filter and checking all the wiring I finally replaced the pump and it works fine.
    Edit:I guess I should really pay attention to the date.
  11. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    That's OK maybe we should dig up some old threads. Seems like this forum has been dying out lately.
