AAAAH! Frustation!!!!!!
Discussion in 'The Garage' started by 84gmcjimmy, Oct 4, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Can anyone give me some tips to get the rusty body mount bolts off? I tried to use the racthet and a cheaper pipe, and that didn't work. Then I found a bigger cheater pipe, [read 8 ft. long /forums/images/graemlins/eek.gif] and that didn't budge the bolt either. Then I tried to heat it up with a little propane torch. IT STILL WONT MOVE /forums/images/graemlins/angryfire.gif I cant get a grinder in there because part of the mount is covering the bolt. I need to get the body off this week (my uncle is here to help take it off...he doesn't know that yet, but he is /forums/images/graemlins/deal.gif) so I neeeed help! I HATE RUST /forums/images/graemlins/angryfire.gif
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Try some penetrating lubricant. PB Blaster, WD-40, or the like. Might help out.
    Kris
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Already tried some stuff called MOOVIT... didn't work
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    torch, the only way i found to get them out.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I tried that and it didn't work. I guess I'll just heat them up longer... when I was doing it, smoke was coming out of the rocker panels /forums/images/graemlins/histerical.gif
  6. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Those body mount bolts go into a hidden square nut buried in a hidden boxed in panel--you want to avoid ripping theese nuts loose from their "cages" so dont use too much force or they will rip loose,or the bolts will snap off,and its not easy to drill and re-tap them.I have cut or ground off the bolt heads with a grinder so I could pull the cab off,then I was able to get at them easier and by welding a nut back onto the bolt shank I could spray the #@#%6 out of the nut thing with penatrating oil and heat them up with a torch until cherry red--then one broke anyway! /forums/images/graemlins/angryfire.gifBut usually you can get them out that way,but I dont think a propane torch will help much,you really need cutting torches to get enough heat.Good luck--been there more times than I care to remember!. /forums/images/graemlins/crazy.gif
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont have a cutting torch, yet...
    How did you grind the bolt off? I have a 5" grinder, and I looked at it a few times and I cant cut the bolt head off or anything, where did you cut it off?
  8. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Under the truck--you can usually pull the lower rubber body mount bushing and washer over the head of the bolt with a pry bar--it might already be missing,usually around here they are!--then you can get at the head of the bolt to cut or grind it off.This will leave the shank of the bolt still in the mounts,so you'll have to pick the tub or cab up a little higher to clear the frame,but its better than chopping holes in the floor to get at the square nut things,of course if the floor is already trashed there,you could eliminate the square nut thing and just put a new bolt through the(new) floor pan,but it will have to be a carriage head bolt so you wont feel a big lump under your feet,or recess it so its flush with the floor. I've rebuilt more chevy cab floors,body supports,rocker panels and cab corners than I can count.I was hoping GM would start using aluminum or stainless for their cabs someday--wishful thinking,but probably not in my lifetime--I need a trip to arizona,so I can see what they were supposed to look like when they were new--all I see around here is rotted junks. /forums/images/graemlins/crazy.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'll look at it again, but I swear mine has a metal cup underneath the rubber bushing, so I cant pull them over the bolt. I'll get a pick tomororw /forums/images/graemlins/dunno.gif
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    just use your torch and start melting down the bushing to where you can pull it out with some pliers them just slide the little cup up and cut off the bolt, all this assuming you are going to replace the bushings /forums/images/graemlins/thumb.gif
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    lol, I starting doing that, but I need to find a mask.. old rubber+penetrating fluid, plus fire= lots of smoke!
    Yeah I will be replacing them when I am done.. /forums/images/graemlins/peace.gif
