AAAARGH!!! Spring hanger and shackle bolts!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SkulzNBonz, Jun 5, 2002.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I am putting a lift on my truck (FINALLY!!!), and the rear spring hanger/shackle bolts are stuck in the bushing sleeves. I am flipping the rear shackle, so I want to try to save the bushings, plus they aren't in bad shape. Anyone have any tricks to getting these bolts out of the bushing sleeves w/o having to cut the bolts. I did cut the bolts off the front springs, but I installed new front springs. Thanks in advance.
    John
  2. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    The problem usually is that the bolt is rusted to the steel bushing, and the bushing gives with the rubber, so it won't release the bolt.
    You can remove these bolts - just keep at it. Use lots of penetrant and let it soak in. One time I had to hook a come-a-long to the head of the bolt with the other side to the opposite spring. Eventually it came out with a great deal of racheting with the come-a-long.
    Also, you can put the nut back on and hammer away. This can loosten up the bolt from the bushing.
  3. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I was thinking along the lines of a C-clamp type press. I am having a guy in our shop fab me one. Any other ideas out there, I know I'm not the only one that has had this problem. Thanks again.
    John
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    You might try a ball joint press. Autozone has a loaner tool.
  5. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yeah, I thought about the ball joint/u-joint press. I have one on loan to me from a friend, but I am still going to have to "Gerry" rig a fixture to get it to work in such tight quarters. Thanks all.
    John
  6. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i had the exact same problem this past weekend on my 91 K5.man those bolts are a PITA!i tied everything,ended up using a ball joint press to push those nasty pricks out.good luck!
  7. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks for all the info, I am leaving right now to fight w/ them again. Will let y'all know how it goes.
    John
