AACKKKK!!! no start after fuel filter change
Discussion in 'The Garage' started by K5dreamer, Apr 10, 2007.
  1. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    Hey all, the truck is an 86 military blazer with the 6.2L diesel, today after work i picked up all the parts i ordered and decided to knock out some small stuff, so i did the oil change, new oil filter, re torqued all the oil pan bolts (VERY glad i did that, one was unscrewed half an inch, right behind the dipstick tube.)
    and then i replaced the fuel filter, pretty easy after i got past the crippling fear it was on the high pressure side of the fuel system. problem is, after swapping the fuel filter, the truck fired right up, ran till the fuel pump was empty, then died. and i cant get it to fire again.
    soooo, im kinda thinkin at this point, was i supposed to fill the fuel filter with diesel before i installed it? is there a fuel pump in the tank? or is it just all pulled up by the pump on the engine?
    thanks everybody ;)
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    make sure the tank is full, fill the filter with diesel, and let it prime the lines, then fill it back up and start it...
  3. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    If I remember right theres somethin by the fuel filter that you turn and it bleeds the line and the filter. After that just keep cranking like hell. I had my old 6.2 C10 dry a couple times back in highschool. 1 of my tanks leaked so I kept it empty. Smartass buddys always loved to get in my truck when I wasnt looking and switch the tanks. Pretty funny lookin back at it Id usually get about a block or two down the road and it would die
  4. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    well the fuel tank has about a half tank in it, it was running right before i swapped the fuel filter, been drivin it all day. i figured it was air in the lines or somethin, and as i recall there is indeed a kinda stopcock kinda lookin thing that leads to a vent tube that empties into the passenger fender, think im gonna go play with it and see if he'll fire up.
  5. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    YAYYYYY!!!! thanks guys, the stopcock it was, and i dont know how long that old filter had been on there, but the truck is MUCH happier now, i hadnt thought about it before, but the old filter was leaking fuel from the bottom, so it may have been REALLY clogged. the truck runs better, runs smoother, has more pickup, and possibly more importantly its way way quieter than it was before.
    thanks so much for the help guys. that one would have driven me NUTS :bow:
  6. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Yeah a plugged filter will kill a trucks performance. I remember my old 6.2 C10 was the same way when I first got it. Ended up changing the filter after i found out the one tank was clear empty. It was like a whole new truck.
  7. Ancient4X4
    Ancient4X4 Registered Member
    Feb 25, 2005
    82
    ND, USA
    Never mind, read that you fixed it, disregard. :)
