AAHHH!! Why do I keep bending my rear springs?
Discussion in 'The Garage' started by TopOff, May 26, 2004.
  1. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Is it simply a matter of too much torque?
    I had 57" Ford springs, with Echobits' shackle flip.
    Now I have 1-ton Chevy springs with two leaves removed. Now I bent these too!
    The passenger side appears to be bent. It was nice and level when I installed them.
    I figure the torque of the transmission keeps bending the passenger side, presuming this is getting most of the power.
    WTH?
    What can I do? Does this mean I need an anti-wrap system?
    Anyone have a good suggestion?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Two words.
    AXLE WRAP.
  3. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Crap. What can I do to fix this?
    Little shock mount system, will this be enough?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    a real antiwarp setup is the best way. Search for antiwrap bars
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    It's either axle wrap, or the rear suspension is binding somewhere when flexed. I would suggest getting your truck completely flexed and look to see if something like the rear shackles are bottoming out. If they are then that could definitely cause bent springs. The suspension should always contact a bump stop before it completely bottoms out otherwise you will stress the springs.
    Concerning axle wrap, I would think that if it was wrapping enough to bend springs then it would be very noticable inside the vehicle.
  6. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    So far it has only been on the street, so I don't think it is a question of bind. /forums/images/graemlins/frown.gif
    How could I tell "inside the vehicle" if I am getting axle-wrap? What would be a sympton???
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Wheel hop. Take it out and floor it. Course that may cause more problems. Have somebody romp on it a little while you watch the pinion in relation to the ground. Should go up a couple degrees but not to much.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Wheel hop is a more extreme example of axle wrap. You should also notice a "clunk" or similar sound from the rear end area when first taking off, like from a stop sign, under moderate power. This sound is made when the spring unloads the axle. I had a 2-wheel drive truck that had shot rear springs, it did it anytime I hit the throttle any more than just easing it off the line...
  9. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    I have been heavy footed, as I have been reprogramming my fuel-injection for my fresh-little rat motor (402-BB). (I broke my ARB in my 14bolt SF just last month).
    I don't think I am getting wheel hop, as my rear tires are spinning and screaming, but they are not screech, screech - screeching - which would indicate, to me, wheel hop.
    Also, I have not noticed a clunk when taking off.
    I guess, I need to look more at some ladder bars, atleast on the passenger side.
