AAHHHHH back up and pic whoring again! PICS!
Discussion in 'The Lounge' started by jjlaughner, Feb 6, 2005.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    35" Wrangler AT/S's
    these tires are discontinued so I had to buy the last set I could find, and they came on Black 6lug rims! WOO HOO
    Pic of the ZR2 sitting atop a parking garage in downtown indy while we where at the Offroad SEMA Show
    Here's some pics from the Proving Grounds at the SEMA show
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Here's why I was offline and not pic whoring
    (yes the tower is actually that tall! its not a sctreched pic)
    Notice the two black face drives....
    1st /top: Samsung 52x CD-RW/16x DVD Combo Drive
    Second: Samsung 16x DVD-RW Dual Layer (2.4x) DVD Burner
    I finally finished the major upgrades to the computer
    AMD 64 PC3200 2.01GHz
    Gigabyte K8NS Ultra 939
    Gigabyte Adjustable CPU cooler with LED's, 1GB OCZ PC3200 dual channel DDR Ram and Clip-over cooler
    Matrox P750 64MB Dual 128bit Processors/Dual DVI output 8x AGP video Card
    74GB 10,000RPM Sata Hard Drive, Raptor Series by Western Digital
    LED's (still need to install my UV lights to lightup my new UV cables)
    [​IMG]...[​IMG]
    Since I have the New Raptor hard drive I had to pull out my old 120gb IDE drive
    So I bought a 1394/USB2 External drive
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Also bought some new Poker Chips for Hold'em Poker nights
    And some KEM plastic poker cards (monaco series)
    AND!!!! I just won this off ebay
    WHISKEY FURNITURE
    [​IMG][​IMG]
    [​IMG] poker table and bumper pool
    [​IMG] backside of the couch
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    damn, thats a pretty flashy comp. how much coin do u have in it?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    in my experience bottom of the case mounted fans are innefficient and make more noise than they add to the cooling. Just stating something for you to think about. Nice full tower, who makes that? And my CPU fan is adjustable too :D I just don't have that blingin 3.5" bay setup :mad: I need to build a watercooled setup again to show you up :).
    So how was Sema offroad? Thought I read it sucked in another post.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    nice rig man... :waytogo:
  7. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Just wondering but why would you need a adjustable gigabit thing? wouldnt you just want it as high as it could go all the time? Kinda like those Banks 6 gun things, If i had one on a Cummins or Duramax id just have it on the highest setting all the time:cool1:
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Bad milage, emissions maybe, controlability in certain conditions
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    at the highest volume its gonna be LOUD, you've obviouslly never heard a loud computer fan or you'd get it.
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Jeremi ah, what is all in there that makes it need such a big tower?
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    personally I would rather have one setting, turn it on and forget it... But the noise these things make at high speeds are crazy, not bad if your gaming or have music/tv turned on but in the same room or down the hall from one at night is crazy (mines in my room). so to set it at 35% its quite (WELL! as quite as 10 fans can be). so when I'm working I can crank it up ( and at night turn it down, it would be nice to have an auto adjusting fan though :thinking:
    As far as the bottom case fan I think it helps a great deal. A silent 92mm fan in the bottom make less noise than an 80mm LED fan exhausting the air through small case holes. My case actually sits 1.5"-2" off the floor on a sheet of plexiglass, so the vacuum caused by the redirection of air cools the air further (the cool air off the floor at that) before it pulls it into the case. Current fan rate is
    -92mm in the bottom (silent)
    -92mm in the front (silent)
    -92mm out the top (silent)
    -80mm in the bottom of the power supply
    -80mm out the back of the power supply
    -80mm in over the hard drive
    -80mm LED fan out the back at the top
    -40mm (or smaller) on the motherboard
    -40mm or smaller on the video card
    -plus the adjustable Heatsink that is far from silent
    In addition to those add in a 52x cd-rom/rw, a 10,000RPM Hard drive, and an External Harddrive a the fan pulling air off the floor is hardly noticable... :cool:
  12. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Is that a syringe?
  13. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Maybe its that super magic goo that makes a nice solid seal between the CPU and the heat sink
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ding, looks like a copper heatsink compound. THe mating surfaces betwen CPU and heatsink aren't always flat and even when they are a very thin layer of heatsink compound between them will help to transfer heat far more efficiently.
    Jeremiah, be a man and get a Delta high output fan :D I ran one of those for about 6 months and left it on while I slept, I slept with a pillow over my head for that time.
  15. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Ive got two questions.......
    Do your house lights dim when you turn that monster on?
    Wrangler AT/S?????????????????
    :grin:
  16. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    with a banks 6 gun, the highest setting is only for limited use. you cant run around all day like that, probly not more than say a 1/4mi..motor will overheat and burn up. thats why there are so many settings. 2 or 3 might be the max you can use for towing, 4 maybe unloaded, 1 or 2 for fuel ecomony.. etc.
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yep its a tube of artic silver thermal paste
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I have a Vantec Tornado but its 56dbs and sounds like a helicopter in my room:crazy: 92mm version pulls 15watts and moves 120CFM :blush:
  19. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    ah yeah... my room is on a breaker of its own for that very reason :cool:
    3 monitors, computer, 32" tv, stereo/dvd players, celling fan and 2 powered subwoofers...
    YEP Wrangler AT/S's! :cool:
