aam 14 bolt front
Discussion in 'The Garage' started by VirginiaBulldog, Jun 6, 2003.
  1. VirginiaBulldog
    VirginiaBulldog Registered Member
    Mar 15, 2003
    74
    Virginia Beach, VA
    I just read the new petersens off road article about the new aam 14 bolt axles. As usual they only seem to half report on them. anybody got some info on them. anyone have them. can they work on a k5? TIA
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I would think that they would be a drivers side drop since they are new, also they would probably be set up to use coils. Though its not like they couldnt be modified to do anything you really want /forums/images/graemlins/grin.gif I would think you would just want to stick to the center section and use the tube assembly on out for your rig. Then again if you want a 14FF just breeze Wagoneermachinehsop.com
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i read that this morning myself.i might just go by the plant, it's only about 1/2 hour ride and see if they have anything that they scrap. some plants will let you have it or sell it cheap.did you also read that the ford super-duty rear is made by visteon. it even says on the manufactuers sheet sterling. they said that's the name of the plant. /forums/images/graemlins/thinking.gif
  4. VirginiaBulldog
    Mar 15, 2003
    74
    Virginia Beach, VA
    those sneeky ford devils /forums/images/graemlins/grin.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    is it a '14 bolt' or a new aam axle?
    calling everything they make '14 bolt' is gonna get confusing fast as we already have 2 '14 bolt's
    they are making a front axle for Dodge to replace the dana60 thing they were using
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    The one i saw under a dodge looked identical to a 14sf in the front.
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    That is my understanding, that it is basically a 14 bolt semifloater rear axle with some slight changes, plus of course steering knuckles.
    -- Mike
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The front is actually a solid-axle version of the IFS front used in GM products. It has a 9.25" reverse-spiral gearset and uses 33-spline axles. My guess is they use a disconnect system rather than locking hubs /forums/images/graemlins/rolleyes.gif
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Wouldn't it have to be a full floater since it's a front axle instead of just a modifed semi-floater... /forums/images/graemlins/deal.gif
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The said no CAD, they also said no locking hubs, so I guess one of us need to stop by the Dodge dealer.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    They are using the ring gear size for a model # 925, 1050, 1150...
  12. u2slow
    May 9, 2001
    2,217
    BC Canada
    AAM says electric or vacuum disconnect on their web site /forums/images/graemlins/thinking.gif I guess full-time is always a possibility /forums/images/graemlins/eek.gif
    http://www.aam.com/technology/tech_prod_dl_frontaxle925.html
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As mentioned, calling them "14-bolts" is pretty misleading. The front axle is probably close in strength to the Dana 60 though is does have smaller in shafts and a slightly smaller ring gear. Dodge does not have any locking hubs or axle disconnect on the axle, just like they have been using on the Jeeps for years now (TJ's have never had CAD either). And yes, the fronts axles are set up for coil springs/ link setup and has a driver's side drop.
    Even if they could be easily adapted to Blazers, I doubt you will be finding very many of them in the junkyards anytime soon or for a reasonable price.
  14. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep
