AARRRGGGHHHH!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Sep 29, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i'm working like mad trying to get my rig up and running for the truckhaeven meet. and its one prob after another. where to start. i got a miss in my motor. i think its the number 8. i just put in new plugs and that one is fauled already. i did a comprestion check and all at about 10 and number 8 is at 9. the motor was running good tilli fixed my vacume leak. wtf is going on wiht it?
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
  2. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i am getting a spark out of all 8 wires. so its not there.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I had a similar problem with a 454 - except it was on #5. It turned out to be a burnt exhaust valve. Try squirting some 30 weight in the hole and run another compression check - see if there's any change.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    ok i'll try that after class tomarrow. and if anyone else has anything to try feel free to help out.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Check your plug wires very closely, and maybe run a wqrench over your intake manifold bolts. Just check for a little looseness. I had a bad miss. Half my intake bolts were finger tight!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    call me crazy but ive heard a lot of people say the oil in the cylinder trick is bogus.. the slightest bit will actually raise compression (like shaving .030 off the heads) and give false readings.. the piston has to be perfectly horizontal and the slightest amount of oil used and only on the rings.
    anyways when I have problems with the rear cylinders, sometimes its the intake manifold vacuum Tee/nipple... if theres a vacuum leak there or theres a lot of air moving thru it, the rear two cylinders get it all making em run lean.. but you say the plug is fouled? that wouldnt happen by running lean, right?.. maybe your intake gaskets are messed up, leaking oil into that cylinder, fouling the plug and making it not fire.. is the plug wet with fuel or oil? hmm..
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The theory I was taught about using a bit of oil in a compression test was this. Do a dry test first and record the numbers. Add a little oil to a cylinder that was low and do another test. If the numbers go up the rings are worn and the oil serves to seal them up a bit. If the numbers stay the same there is a loss at the valves.
    Rene
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That's the same theory I was taught - quick way to rule out rings.
  9. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    its foulded with oil. haven't smelled it to tell if there is gass on it yet.
  10. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Stu, check your intake manifold then. Also check your radiator. My intake was sucking water as well!
    Jim
  11. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i just checked the intake. none of the bolts were lose. my pampaw offered to take it down to have it put on an anilizer. so i'm going to check out some more stuff and if i have no luck then i will take it down.
  12. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Are you back in town? Ive been to Redington a few times with a new friend of mine from the kids football team. He's got a nice 85 blazer. When you get it running again we'll go out for a day.
    Jim
  13. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    You know what? We might be doing his front brakes at my house tomorrow afternoon. Maybe you can come over, we'll figure it out. I don't have a compression tester but we can figure something out. Send me a PM or email with your number and I'll give you a shout.
    Jim
  14. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    yeah i'm back in town. my wheeling friend just moved back to colorado so i out a wheeling buddy
