Abnormal 700r4 problem!
Discussion in 'The Garage' started by RockBurb, Mar 31, 2004.
  1. RockBurb
    RockBurb 1/2 ton status
    Jul 30, 2001
    106
    Moscow Idaho
    Ok heres the deal. When my transmission is coasting in 3 or 4th it makes a horrible grinding noise momentarily, and then will do the same for a moment once you depress the gas again. The transmission has less then 7000 on a full rebuild, and was working perfectly before I pulled it from my Suburban to put it in my K5 /forums/images/graemlins/cool.gif. I did happen to break a rear ujoint wich caused the back of the 700r4 where it bolts to the Transfer case to break, but I had it welded by a professional, and it looks as good as new. I have unhooked the tcc wiring so this is not the problem, and I have played with the tv some. Please help!
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i did the same thing
    do you know if the rebuilder replaced the sun shell? that could be what the problem is. i had that happen once, the tranny had 6000 miles on a rebuild when it did it.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Mine makes the same type of noise also in hi gear. It only does it when I am partly on the throttle where it isn't coasting but isn't sending power to the rearend either. Sounds like it is coming from the bellhousing and I know it isn't the tranny because it started acting up before it was rebuilt. I am wondering if I didn't get the flexplate bolts that hold it to the crank torqued down properly and are backing out causing the flexplate to vibrate when it doesn't have a load on it. But just an idea. /forums/images/graemlins/whistling.gif
  4. RockBurb
    Jul 30, 2001
    106
    Moscow Idaho
    I dont know for sure if the sun shell was replaced or not. I do know that the torque convertor is on tight as I just had the tranny off of the truck. Furthermore I pulled the governor and it looks ok as well /forums/images/graemlins/frown.gif. This has me stumped!
  5. RockBurb
    Jul 30, 2001
    106
    Moscow Idaho
  6. RockBurb
    Jul 30, 2001
    106
    Moscow Idaho
    No one else has ever had this problem?
  7. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    I've got the same problem with my 700. I'm not sure what is causing it, but it's been doing it for a while. Mine is also slipping out of gear when I get on the gas going up hill. Instead of downshifting, it slips causing the engine to race. If I let off the gas, the rpm's drop and the tranny kicks back into gear. I figured the problems were inter-related, but maybe not.
  8. RockBurb
    Jul 30, 2001
    106
    Moscow Idaho
    I talked to the trans guy, and he doesnt think its anything internal, but rather the torque convertor. I have an appointment for tuesday to have it looked at and I will let you know what I find out.
  9. 86bigblazer
    86bigblazer Newbie
    Apr 3, 2004
    California
    I have the exact problem, however it is not my tranny it is the transfer case, I took it to my tranny guy and that is what he said the noise was coming from.
