? About 9012's in the rear ...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SlyDog, Dec 23, 2001.
  1. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    ? About 9012\'s in the rear ...
    Hey, can I install rs9012's in the rear without any shock mount modifications? This is for a 4" lift ...
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Re: ? About 9012\'s in the rear ...
    Hell you can do anything you want. I think min measure is like 19.5 and max is 32.25, Your compression would be the issue to look at. You could do it for a little while, then mod the mounts, so you could get the 9012's in the beginning and then just mod the mounts later, that way only paying for shocks once
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have to agree with Joel on this. On the back with stock mounts 9012's should not be a problem.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  4. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    But compression would be an issue right? Would you reccomend I should go with a smaller shock If I decide to stick with the stock mounts? What rancho shock would it be? Thanks!
    BUILT NOT BOUGHT
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I don't see why compression would be an issue since it will only compress so far just like any other shock. I think the key is how much extension it will have. With 9012's the shock will not bottom out so that will be good. The weak link to the whole thing is the factory upper shock mounts. They have a habit of breaking.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Compression is the main issue, because the shock mounts (and the shock itself) were not designed to be used as bump stops. Slam the shock fully closed, with the full weight of the truck and something will break. [​IMG] You want the axle to hit the bump stops before the shocks bottom out.
  7. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    Yeah, if you have enough flex to botom any shock out in the rear you'll shear a mount off. Upper or lower depends on which mount is the weakest. I busted an upper drivers side and a lower passenger side before I relocated the shocks...and that was with rancho's for a 4" lift. Both times the mounts busted at full compression when the shock bottomed.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  8. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    just mount the upper shock bushing to the header with some ducktape. i had a friend who did it and it lasted for a million years and he wheeled 900 hours a week. but sometimes he overexaggerated.
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Should upgrade to a new shock mount[​IMG]
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  10. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Without upgrading the mounts, what shock should I get for the rear? Part number appreciated [​IMG]
    BUILT NOT BOUGHT
