??? about a 94 sub..
Discussion in '1936-Present Suburban' started by gokartergo, Nov 26, 2003.
  1. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    A friend of mine as a 94 sub.. He just called me he lost the tranny.. No reverse and all he as is first gear.. What tranny is that it is a 94 2 wheel drive. It as the overdrive.. I now they where 700R4 up to 91.. What was after that Thanks Dan /forums/images/graemlins/1zhelp.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    4L60E most likely in a 1500. 4L80E in a 2500.
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Whichever he has it just blew the cage for the sun gear assembly. Common weak point in these trannies.
    Same thing happened to mine but that was becasue I let the wife drive it and she likes to hammer it right after shifting it.
    When that gear set goes it can't shift into second or fourth anymore so your stuck in first. Probably lots of debris in the fluid and I bet it smells like it's fried. When he replaces the tranny tell him to add a external cooler as well. The Burbs never had adequate tranny cooling even with the towing package. When he gets it replaced he ought to also have the shell upgraded at the same time it costs a few bucks more but eliminates one of the weakest points in those trannys (4l60E's and 700R4's).
    Two good places to check for upgrade options would be PATC
    and Bowtie Overdrives
    They can point him in the right direction for the HD parts he'll need then he can have it built by whomever he chooses, but I'd recommend BowTie Overdrives myself.
