? about amp and speaker setup
Discussion in 'Audio' started by jackyl, Apr 5, 2002.
  1. jackyl
    jackyl Registered Member
    Oct 8, 2001
    52
    Idaho
    I have two Cerwin Vega 12's. They are 4 ohms and 800 watts peak each. I wanted to run a Fosgate BD 1000 one channel amp. Can I run this amp and speakers? Someone told me that I cant because of the ohms being to low on the amp.
  2. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    Sure, you can use this combination. Wiring the speakers in a "parallel" configuration will result in a 2 ohm load, which is a little low, but Fosgate makes great amps that will handle it with no problem.
  3. jackyl
    Oct 8, 2001
    52
    Idaho
    How do you run them parallel?
  4. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    the mono block fosgate amps are designed and rated at 2 ohm load... taking the 2 subs being 4 ohm each and running them in parrell will result in a 2 ohm load thus getting the most out of the amp at what it is rated at.. To run the subs together in a parrell configuration is simple.. Basically take the positive from each sub and put them together.. then take the negitive from each sub and put them together.. then plug those into the amp..
