?? about caster/camber
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Jimmy, Dec 12, 2002.
  1. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Gonna do ball joints etc pretty soon on my 10B...I'm noticing that the outer edges of my tires are much more worn than the inners...no feathering or unusual wear on either side, but considerably more wear outer than inner (don't think it's just from turnin' corners)...question is do they make such a thing as caster/camber sleeves that allow you to set camber in order to do a more complete alignment, or do ya gotta heat and bend expensive stuff, or will replacing the ball joints, etc sorta automatically bring things into spec (assuming axle tube,etc ain't bent)...
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It depends, if your ball joints have play in them you might be OK when you replace, however if not, there are sleeves that go on the top ball joint IIRC and there is a special tool to set it up, it's an offset sleeve.
  3. codeman
    codeman Registered Member
    May 8, 2002
    42
    Lincoln, Nebraska
    Check your toe in. My tires were wearing the same way until I reset my toe.
