? about Fluids
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Mar 31, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have an 89 Jimmy with a 241 T-case and don't have the owners manual. What I need to know is what they reccomend for the fluid in the T-case and how much. Also need to know how much tranny fluid they reccomend when service is done to a TH700r4. Also need the plug gap. Thanks.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    hold on I'll go check in my manual.
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I appreciate it!!!
  4. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    I think Dextron III, but what do I know?
  5. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    for the t-case it just says to use automatic trands. fluid labeled dextron II and fill it up to the filler plug hole. For the tranny fluid, it doesnt say just to go by the dipstick reading, I think when I changed mine it was about 4 quarts?? I know there is alot in the torque converter already. I'm sure if you called a dealership and asked for the service dept. they would be able to tell you exactly. It doesnt say the spark plug gap either it says it is in the maintenance shcedule book that i dont have!!! Sorry thought I could help.
  6. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Thanks alot. I plan to do this tomarrow and the dealer's are not open.
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Wayne, look on the radiator support, under the hood. There should be a white sticker there with emissions info on it; you should be able to find the plug gap there.
    A far as xfr case goes, about 4 quarts should do. My 208 took just over 4 qts, and I believe the 208 and 241 are almost identical.
    [​IMG] Semper Maintenance!
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    T-case takes dex II or equiv... which means you can use Dex III (aka ATF). You'll probably need 5 or so qt's of atf for the trans and another 2 or 3 for the t-case... I'd just pick up a case rather then 8 qt's (get one extra for sure...).
    1987 Chevy K5 Blazer- 350 TBI
    <P ID="edit"><FONT SIZE=-1>Edited by CaptCrunch on 03/31/01 07:15 PM (server time).</FONT></P>
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I thought of that right after putting it on the post. Went out and looked and sure enough .35. I wasn't sure if the TBI 350 was differant then a carb. Thanks again.
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Do yourself a favor and get a suction pump from the parts house for filling up the t-case. You will thank yourself. It works for differentials too.
    90K5
    <P ID="edit"><FONT SIZE=-1>Edited by 90K5 on 03/31/01 09:22 PM (server time).</FONT></P>
  11. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    You called? All the other replys sound good. Dextron III can take the place of ALL other G.M. (!!!) ATFs. All the way back to the days of the 'glides. Dex III is better stuff, I'd fill the trans with it, but the T-case fluid isn't all that important, not alot going on in it. Just keep it full of ATF, and forget about it.
    Twiztid
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I filled my case up with Mobil 1 - now i'll forget about it and probably never change it again...[​IMG]
    90K5
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Just keep it full! Those cast iron suckas need 80/90, Steve (THE K5 guy) says to use motor oil, if I remember right. That sounds O.K. to me too. Like I said, not alot going on in 'em.
    Twiztid, Fogit about it!, Ha!
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    NP203 10/30 or 10/40
    NP205 80/90
    NP208, NP241 ATF
    90K5
  15. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Not to keep this going- but- Where did you get that info? I'm not argueing, just asking. Learn somthin' new everyday on this site! Ain't it great!
    Twiztid
